3rd gear flame out - Club700XX - Honda TRX700XX Forum
post #1 of 8 Old 03-04-2010, 08:04 PM Thread Starter
oops 3rd gear flame out
i have a fmf q4 screen in, 13 sprocket, uni filter, fmf programmer, and razr2 22 front ,razr rear22, its been real cold and alot of snow and water. heres the problem when im on it hard in 3 or 4 gear it flames out kinda like its flooded, it just dies, at not a good time i may add. it never done that till the programmer was installed, i had the opposite it would die on the low end . so where do i start?
ssxr600 is offline
post #2 of 8 Old 03-04-2010, 08:48 PM
BiFfMaN's Avatar
Hows the connections on the programmer? could be a issue in the injector wire or RPM wire.
if not might be too much fuel at top end RPM.
$tock
BiFfMaN is offline
post #3 of 8 Old 03-04-2010, 08:52 PM
MizuriDirt's Avatar
Are you still running the stock lid??
MizuriDirt is offline
post #4 of 8 Old 03-04-2010, 10:08 PM Thread Starter
yes stock lid
you dont stop riding because your to old, you get old because you stop riding!
ssxr600 is offline
post #5 of 8 Old 03-04-2010, 10:11 PM Thread Starter
im going over all the connections first then im thinking like you it might be getting to much fuel, but it doesnt bog it just shuts down
ssxr600 is offline
post #6 of 8 Old 03-05-2010, 11:53 AM
warlock28's Avatar
Pull the plug right after it happens to see what it looks like.
2008 TRX700xx X 2
2003 Excursion V10 (Pull Toy)
warlock28 is offline
post #7 of 8 Old 03-06-2010, 12:20 AM Thread Starter
warlock ill try that the next time i get in the woods, i never had that problem till i put on the programmer im thinking its dumping to much fuel and flooding it out
ssxr600 is offline
post #8 of 8 Old 03-06-2010, 07:36 AM
warlock28's Avatar
You may also want to check the stock map of your FMF to make sure it has not changed. You could also disconnect the FMF and try it again.
2008 TRX700xx X 2
