Trail tech computer/ steering damper?? - Club700XX - Honda TRX700XX Forum
post #1 of 7 Old 03-06-2010, 02:46 PM Thread Starter
I am wanting to install the trail tech computer with the dash/barclamp setup they have. I am wanting to install a cncc steering damper that some of you have used. Will they interfere with eachother? Im not sure where the steering damper is mounted in relationship to the bar clamp. Anyone use this setup? Thanks for any help
ohmatman is offline
post #2 of 7 Old 03-06-2010, 03:26 PM
If you mean the CCP steering damper... it's mounted at the base of the steering stem and clamps to the frame and stem down there.
post #3 of 7 Old 03-07-2010, 01:43 AM Thread Starter
Yeah, meant CCP. OK shouldnt interfere with trail tech vapor then, Thanks for your help
ohmatman is offline
post #4 of 7 Old 03-07-2010, 11:26 AM
There is a couple of threads on mounting the CCP in the "Suspention..." section. The 2 things about the mounting is that first your rectifier needs to be moved a bit... It's not in the way, but the wires are. The wires come out at the back and stick out. The instructions will tell you to turn the rectifier around 180 degrees so that the wires are coming out of the front. However, if you do that, you'll find that this will stretch the wires... not enough slack. You can remove some of your front plastic to get to the wiring above and un-clip to give yourself more slack. Or, you can make a bracket to tilt the rectifier up at about 45 degrees... which is what I did. The second thing you'll need to do is move your front brake lines back a bit. The "T" connection behind the steering stem needs to be moved back about 1/4 - 1/2 inch. Some have just used a screw driver and bent it back... but bending something like that makes me nervous. I choose to cut off the frame bracket and re-weld it back the needed distance.
BTW - You'd have to do the same things with the other steering dampers out there... Elka and Precision.
post #5 of 7 Old 03-07-2010, 11:04 PM
phucknutz's Avatar
he is 100% correct, your only issue is the vapor will mount differently if you change your steering stem as will the size of the steering stabilizer clamp. If you plan to change the stem do it first and then order the stabilizer and specify the clamp size.
Big Kidz Racing
Sponsors:
EHS Racing
Barker's Performance
Houser Racing
On The Trail TV
West Virginia ATV Tours
Hinsen Clutch Components
KBC Helmets
Hiper Racing Wheels
Member:
Score International
Best in the Desert
phucknutz is offline
post #6 of 7 Old 03-08-2010, 08:38 PM
dagirl71's Avatar
can I tell you my first ride with the CCP steering dampner was yesturday and I was so impressed...went over train tracks, climb up and down serious rocky hills(love the 13t), numerous down trees and my bars didn't pull once from my hands...I was amazed I could not find enough shit to ride over... not to mention I was riding slow yelling look no clutch no clutch!!!
Da Girl
dagirl71 is offline
post #7 of 7 Old 03-15-2010, 02:47 AM Thread Starter
Thanks for all the info!!
ohmatman is offline
