help...need to buy a kill switch?? - Club700XX - Honda TRX700XX Forum
post #1 of 41 Old 03-09-2010, 03:00 PM Thread Starter
dagirl71's Avatar
ok so need to buy a tether kill switch... anyone using any? also do I have to wear that crap all the time or just when I have too? The Honda dealer here sells them for $79 but see them for less...
when I called rocky mtn they said they dont make one for our quad...aren't they universal?
Da Girl
dagirl71 is offline
post #2 of 41 Old 03-09-2010, 03:29 PM
skier207's Avatar
I found a marine one for less than $20. I will see if I can find the link.Works normally open or normally closed. No they're not all the same the XX needs a normally closed switch. No you don't have to wear it all the time just loop the tether around the handlebar.
Found it.
http://www.offshorewake.com/store/Se...SWITCH-WTETHER
The only thing is you need something to mount it to. Like a aluminum plate mounted to the handlebar/clamp.
skier207 is offline
post #3 of 41 Old 03-09-2010, 06:35 PM Thread Starter
dagirl71's Avatar
thanks!
Da Girl
dagirl71 is offline
post #4 of 41 Old 03-09-2010, 07:06 PM
skier207's Avatar
If I get a chance this week I will post up pic's of where I tapped into the circut and my install.
skier207 is offline
post #5 of 41 Old 03-09-2010, 07:20 PM
gavineli's Avatar
they are selling some on ebay too
http://cgi.ebay.com/ebaymotors/Pro-A...Q5fAccessories
gavineli is offline
post #6 of 41 Old 03-09-2010, 07:27 PM
skier207's Avatar
Originally Posted by gavineli View Post
You need to make sure this is a normally closed switch. Which is not the most common type. When I was looking for mine I seem to remember some switches requiring an adapter (additional cost) to use with a normally closed circut.
skier207 is offline
post #7 of 41 Old 03-09-2010, 07:29 PM
gavineli's Avatar
Thanks for the heads up was thinking about getting one didnt even know there was a diferance
gavineli is offline
post #8 of 41 Old 03-09-2010, 08:28 PM
He is absolutely correct. The normally closed switch is easier to connect up, you can tie it right into your kill switch wire, which is what I did.
Nikki, you do not have to wear it all the time, just when you race. It is just for falling off, so your quad stops sooner than later, however it isn't a bad idea to wear it all the time. Once you install it, you can't really take it off. If you need help finding one, I got mine thru my shop, and it said right on the package that it was for a 700xx (along with a 400ex), just let me know, and I will give them a call and see how much it is. I get 30-40% off usually. It was a pain to install because I was in a hurry and sometimes have zero patience, but it can be easily installed in 20-30 minutes.
post #9 of 41 Old 03-09-2010, 10:00 PM Thread Starter
dagirl71's Avatar
That would be AWESOME!!! Thanks!
Da Girl
dagirl71 is offline
post #10 of 41 Old 03-09-2010, 10:07 PM
proarmor $30.95
