IF You Have A Pro Armor Kill switch Please ? - Club700XX - Honda TRX700XX Forum
post #1 of 5 Old 03-13-2010, 11:58 AM Thread Starter
Shovelhead's Avatar
OK, I know there has been much discussion on kill switches for XX. Yes it is a "closed" not "open system. I have a Pro Armor switch that says it will fit universally not specific to any perticular bike..
The instruction tell you how to wire it up & mentions nothing about "open" or "Closed"........
so......
Will it work? If you have one did you hook it like Pro Armor says? one wire to ground...one to wire between stator & ignition coil?
DO NOT CONNECT TO THE HIGH VOLTAGE SPARK SIGNAL AFTER THE COIL
I know many of you guys & gals have kill switches & I think Not everyone has those $$$ closed Gunnar switches..
any info greatly appreciated here..
Shovelhead is offline
post #2 of 5 Old 03-13-2010, 05:35 PM
This should help.
https://club700xx.com/vb/showthread.php?t=1093
And yes it does work.
post #3 of 5 Old 03-13-2010, 05:51 PM Thread Starter
Shovelhead's Avatar
Originally Posted by Baxter View Post
This should help.
Thanks Baxter...Where you been lately? Racing?
post #4 of 5 Old 03-13-2010, 07:50 PM
so......
If it is to stator and ignition coil, it is a normally open circuit. One quick way to check, if you have a multimeter, check the resistance with the lanyard in, go from the end of one wire to the other, if it reads 0ohms, you have a closed, if it reads infinite, you have an open. if you dont have a multimeter, you can use a test light, and hook one wire up to a battery, and the other to the light and the light to ground.
post #5 of 5 Old 03-14-2010, 12:32 AM
Just been busy at work and adding new bits to 700xx . Plus trying to find some bits for it .
