FMF Powerbomb heat shields or not? - Club700XX - Honda TRX700XX Forum
post #1 of 12 Old 03-14-2010, 03:42 PM Thread Starter
Shovelhead's Avatar
Ok you guys with FMF Powerbomb head pipes...Did you re-use the stock heat shields as they said to do? Or just let it eat like it is?
Pics are a plus if you did use shields..or aftermarket shields..
Thanks
Shovelhead is offline
post #2 of 12 Old 03-14-2010, 04:19 PM
chance's Avatar
I don't personally have the FMF pipe on my bike, but a friend of mine does. He used the stock shields, and I powdercoated them with some high heat black. They look great, but to each his own. I personally didnt like the gold stock color...balck or silver is the way to go.
2008 700XX:
Power Commander 5
EHS Lid
Uni Filter
Barker Full Exhaust
Renthal 13 Tooth
Powdercoated Grab Bar, Controls, and Motor Mounts
chance is offline
post #3 of 12 Old 03-14-2010, 05:05 PM
I've got the powerbomb header and do not run the heat shield. Pics below
https://www.club700xx.com/vb/showthread.php?t=2305
post #4 of 12 Old 03-14-2010, 05:15 PM Thread Starter
Shovelhead's Avatar
Thanks Smoooth1 . That thread was exactly what I needed..I knew I had seen some somewhere with & without..You havent had any heat issue without shield ? Like gas vapor lock or any wiring issues? I guess not since you have had it a while now..
Many thanks!
post #5 of 12 Old 03-14-2010, 06:18 PM
I dont run the heat shield either, just be sure not to keep your leg right next to it unless you got some good boots, cuz I burnt a hole right thru my carharts and pants into my leg . hurt like a mofo.
post #6 of 12 Old 03-14-2010, 10:58 PM
Same here, I burned a hole through my riding pants. I'm sending it off to get ceramic coated next week. Other than your leg there is nothing close enough to get damaged from heat. I didn't think the stock shield would fit but someone posted pics last week of there powerbomb header with the stock one installed.
post #7 of 12 Old 03-14-2010, 11:55 PM
Did you have flames on yours? I did, LOL. Brand new set of carhart bibs too. The flames were starting to come up, so I jumped off and used snow to put it out. 3rd degree burn from it, felt amazing.
post #8 of 12 Old 03-15-2010, 01:05 AM
No, I had some Fox pants on and it just melted a hole in them. I thought my XX was overheating because of the smell till I realized what it was.
post #9 of 12 Old 03-15-2010, 02:58 AM
HAHA, I felt my leg getting warm, so I put my leg further out on the nerfs like normal, to let it cool off, and it kept getting hotter, then I looked down.
post #10 of 12 Old 03-15-2010, 10:16 AM
chance's Avatar
WOW! I hate that. Look down and your leg's on fire...nothing like the feeling of burning flesh. I know that my Fly Racing boots keep my pants and skin in tact. Boots can get expensive, but so can buying new riding pants after every weekend.
2008 700XX:
Power Commander 5
EHS Lid
Uni Filter
Barker Full Exhaust
Renthal 13 Tooth
chance is offline
