What oil is everyone running...what interval?? - Club700XX - Honda TRX700XX Forum
post #1 of 25 Old 03-14-2010, 07:26 PM Thread Starter
700ATP's Avatar
Don't want to start a war,.....just want what your running, and filter brand and interval.......
thanks Guys.
08 700xx....Turkey Bay Rider....
700ATP is offline
post #2 of 25 Old 03-14-2010, 07:34 PM
09RappySE's Avatar
Quoted: 16 Post(s)
Klotz MX4 10w-40, K&N oil filter, change every 10hrs.
734 09 Raptor
Tuned by EHS Racing 78hp 55Tq
09RappySE is offline
post #3 of 25 Old 03-14-2010, 08:05 PM
Silkolene semi-synthetic Comp 4 sx 10w40 , Hiflo filtro filter , changed every 3 hours. Kinda extreme but oil is cheaper than metal.
post #4 of 25 Old 03-14-2010, 08:07 PM
Motul 5100 10w40 (I think) and PC racing Flo reusable filter.
2006 Raptor 700
post #5 of 25 Old 03-14-2010, 08:52 PM
Honda oil and just a paper filter from them. and change it depending on how hard I ride, 8-20 hours.
post #6 of 25 Old 03-15-2010, 12:08 AM
Honda synthetic with K&N oil Filter. I'm not very good with keeping up on hours so I usually just change it every other month or so. I check it frequently and will change it if I notice its starting to get dark also.
post #7 of 25 Old 03-15-2010, 12:19 AM
post #8 of 25 Old 03-15-2010, 10:06 AM
Tory trx's Avatar
Honda oil and filters and change them every couple of rides. Had the bike since the beginning of December and have changed the oil five or six times.
Tory trx is offline
post #9 of 25 Old 03-15-2010, 11:10 AM
VelociRaptor's Avatar
Changing the oil too often is almost as bad as not often enough. Each time you drain it it has to reprime through the engine on start up. 10hrs is the about as often as you would want. If I changed my oil every 3 hours I would have to change it every time I ride, thats alot of time for the engine to be without oil pressure until it reprimed.
Bo White
205-886-7043
VelociRaptor is offline
post #10 of 25 Old 03-15-2010, 12:16 PM
Tory trx's Avatar
It makes sense. When I ride I try to make a day of it so the bike is moving for about five or six hours a ride. I tend to ride one or two times a week when its nice out, and I change it every couple of rides, so that would be an average of about ten to twenty hours every oil change.
Tory trx is offline
