Engine Noise - Club700XX - Honda TRX700XX Forum
 1Likes
  • 1 Post By cataway
post #1 of 8 Old 01-30-2017, 03:09 AM Thread Starter
Hondatoy09's Avatar
Quoted: 4 Post(s)
Engine Noise
Hello everyone. My first post but been lurking for a while.
I purchased a 2009 700xx last july. Ive only ran 93 octane in it since Ive had it. Anytime the engine is under heavy load I can hear a jingling noise in the engine. Climbing a hill or fast acceleration. It does sound like fuel detonation. I installed a fuel programmer and adjusted the valves. Neither eliminated the problem.
Anyone else experience this or have any ideas?
Hondatoy09 is offline
post #2 of 8 Old 01-31-2017, 05:32 PM
Quoted: 141 Post(s)
missing screw in a heat shield?
cataway is offline
post #3 of 8 Old 02-01-2017, 04:06 PM Thread Starter
Hondatoy09's Avatar
Quoted: 4 Post(s)
I read that on another post on here somewhere about exhaust bolts coming loose. But no I checked everything there. All mounting bolts on the stock exhaust and heat shield are tight and solid.
Is there a way to find out if something is bad internally without tearing down the engine? It doesn't smoke.
post #4 of 8 Old 02-01-2017, 06:18 PM
Quoted: 141 Post(s)
just wondering what it would sound like if the timing chain were loose
cataway is offline
post #5 of 8 Old 02-03-2017, 05:10 AM Thread Starter
Hondatoy09's Avatar
Quoted: 4 Post(s)
Under the troubleshooting section in the Honda service manual for engine knocking these are the listed possibilities:
--Worn piston and cylinder
-- Lean fuel mixture
--Faulty CKP sensor
--Use of poor quality fuel
--Excessive carbon buildup in combustion chamber
--Ignition timing too advance (Faulty ECM)
If any sensor was bad, wouldn't the engine light on the handlebars be on?
post #6 of 8 Old 02-03-2017, 02:41 PM
Quoted: 141 Post(s)
first you say its a jingling noise in the engine.. now its a knock?
M_Quick likes this.
cataway is offline
post #7 of 8 Old 02-03-2017, 05:06 PM Thread Starter
Hondatoy09's Avatar
Quoted: 4 Post(s)
Knocking was the closest thing in the troubleshooting section. Timing chain noise can be heard during idle from what Ive read.
post #8 of 8 Old 02-03-2017, 06:20 PM
Quoted: 141 Post(s)
there is a chain tensioner on the cam chain . is there a way to see if its all the way out ?
cataway is offline
