Installation set-up FMF Programmer..HELP! - Club700XX - Honda TRX700XX Forum
post #1 of 8 Old 03-16-2010, 06:42 AM Thread Starter
Shovelhead's Avatar
anyone out there with FMF programmer who can give me some info on strting point to program this would be great.
I have Powerbomb header, FMF prog. & Airbox lid from EHS. I thought it would be programmed from factory for starters, but it doesn't say so..
What settings do you have that I could use to get started?
Thanks for any help..Gonna try to install & get running today..
Yes, I tried to search , but it keeps saying something about not eneough letters / words or something..
Shovelhead is offline
post #2 of 8 Old 03-17-2010, 06:37 AM Thread Starter
Shovelhead's Avatar
What no one wants to give up their settings?? Ok be that way!
post #3 of 8 Old 03-17-2010, 07:34 AM
warlock28's Avatar
Just installed mine and the programming seems good from the factory. You may want to call FMF to findout for sure. You can also check the plug after a few runs to see what it looks like.
2008 TRX700xx X 2
2003 Excursion V10 (Pull Toy)
warlock28 is offline
post #4 of 8 Old 03-17-2010, 10:44 AM Thread Starter
Shovelhead's Avatar
So Warlock, you just hooked it up & ran with it? That's sweet..atleast a good starting point. Thanks for the reply..
post #5 of 8 Old 03-17-2010, 03:20 PM
warlock28's Avatar
I think the instructions that came with it have the default program setting for the 700xx in it. I will check when I get home.
2008 TRX700xx X 2
post #6 of 8 Old 03-24-2010, 02:46 AM
markas214's Avatar
Warlock I'm going to have the same set up. UNI, 4.1 and FMF controller. 4.1 header is back ordered until May 5. Got the slip on and UNI on the way. How does your 700 run compared to stock? Do you have the 13 tooth sprocket. Did you go straight to the header or run with the stock pipe first?
markas214 is offline
post #7 of 8 Old 03-24-2010, 06:28 AM Thread Starter
Shovelhead's Avatar
Yes, I got mine installed & it runs pretty damn good with the factory program in it..I will fine tune it as weather breaks & humidity gets bad..I like it!!
post #8 of 8 Old 03-24-2010, 07:49 AM
warlock28's Avatar
Here is a link to my install if your interested.
https://www.club700xx.com/vb/showthre...?t=2305&page=2
I run in the desert so with the mods no need to change sprockets. I also do some mountain riding and have not found the need to change. The mods made a huge differance in power and control. Did the same mods to the wifes 700xx and she has no problem even in the tight stuff. She moves at a little slower pace than I, but has not complained. She says "It doesn't matter what gear I'm in - I just give it more gas and it goes" - LOL
2008 TRX700xx X 2
