Weird Noise - Club700XX - Honda TRX700XX Forum
post #1 of 17 Old 03-16-2010, 10:57 PM Thread Starter
Weird Noise
This weekend I change the oil and filter and did intall the filter the proper way (O ring out) and noticed when I start the engine, I can hear a winding noise coming from the clutch casing, the one behind where the oil filter casing is and it goes away about 30 seconds or when I pull the clutch in then the sound is gone for good. I know that I used the clutch quite a bit on the last ride especially feathering it due to the logs and boulders but it doesn't slip or anything when I have it in gear and engage the clutch....weird!!! Did not noticed the sound prior of the oil change since I was not really paying attention, the only reason I did this time is because I was inspecting for leaks. Any suggestions?
Thanks
post #2 of 17 Old 03-17-2010, 05:05 AM
Joe, did you try running it for a bit before the oil change? If not, the possibly the oil drained out of the clutch housing, and it just needs to get back in there, even though I dont know why that would make a noise (pretty sure it wouldn't but just a thought). You check the bolts on the cover to ensure they are tight.
post #3 of 17 Old 03-17-2010, 06:33 AM Thread Starter
Did warm up the engine prior of replacing the oil and torque the bolts, I'll start it again tonight and if issue persist might just take it in. How long is our warranty?
Thanks for the info.
post #4 of 17 Old 03-17-2010, 06:37 AM
Tory trx's Avatar
Did you check the oil crankcase level after changing your oil? Maybe your oil screens are clogged up.
Tory trx is offline
post #5 of 17 Old 03-17-2010, 10:51 AM Thread Starter
Yeah! Did not think about the screens, will check it out this weekend. Oil Level is good.
Thanks for the info
post #6 of 17 Old 03-18-2010, 04:08 PM Thread Starter
Well I check the oil filter and is installed properly so I added some oil due to removing the filter and started the bike and the sound is still there so now I need to see if my warranty is still good. Pretty sure they'll blame the clutch for wear and tear but I'll try it anyway.
post #7 of 17 Old 03-18-2010, 04:52 PM
Tory trx's Avatar
Good luck. Hope everything is OK.
Tory trx is offline
post #8 of 17 Old 03-18-2010, 06:17 PM Thread Starter
Thanks, dropping off the bike tomorrow after work, warranty is valid till mid April so better take care of it now.
post #9 of 17 Old 03-18-2010, 07:33 PM
Mine never had done that best to get it checked a broken toy is no fun.
silliestdaddy is offline
post #10 of 17 Old 03-20-2010, 03:39 PM Thread Starter
Well brought it in to my dealer and they said that since it could be a worn clutch which is not covered under warranty then they would bill me for the labor/parts so I told them to shove it and if the clutch is worn out then I would replace it myself with an aftermarket clutch since the OEM is a POS. Never had a clutch wore out that fast.
