ecm plug problem - Club700XX - Honda TRX700XX Forum
post #1 of 6 Old 03-17-2010, 05:52 AM Thread Starter
ecm plug problem
hello guys i need your help. today i decided to to remove the reverse rev sensor glad i did. i rolled back the clear plastic cover over the top of the ecm loom and located the wires i needed to cut.
now this is the problem i removed the multi plug from the ecm unit and found the unit full of water. now i have never removed the plug before. but there is not any rubber seal around this plug. do you know if your ecm as a rubber seal to stop water getting in.
cheers gary
mods to my trx700xx
corsasri is offline
post #2 of 6 Old 03-17-2010, 05:58 AM
Tory trx's Avatar
Mine didn't. That plastic rap was the only thing in there to protect it.
Tory trx is offline
post #3 of 6 Old 03-17-2010, 06:18 AM Thread Starter
maybe yours is missing the seal to. lets see what other members say
mods to my trx700xx
corsasri is offline
post #4 of 6 Old 03-17-2010, 09:49 PM
kennyg700xx's Avatar
nope, no seal, just plastic.
2008 honda700xx
2007 honda250ex(wifes)
2009 FORD F150 supercab
kennyg700xx is offline
post #5 of 6 Old 03-17-2010, 10:07 PM
valk680's Avatar
When I took mine apart it had dirt/sand inside. Everything still works perfect. I was going to wrap the plug with electrical tape but was fear full it could hold more "crap" inside there so I didn't do it.
715 11:1 big bore
+1 intake valves
Sredrums +3 throttle body
PCV
NGK BKR6EKPB-11 spark plug
K&N air filter w/outerwares,
Barker exhaust
PBI sprockets /D.I.D chain
Stage 3 Elka's on all 4 corners
valk680 is offline
post #6 of 6 Old 03-19-2010, 04:17 PM
Shovelhead's Avatar
No seal here either..still looking for a solution or not
Shovelhead is offline
