Managing Throttle Response - Club700XX - Honda TRX700XX Forum
post #1 of 15 Old 02-04-2017, 04:35 PM Thread Starter
I am a new owner of a Honda TRX700XX. What I don't like is the twitchy throttle response. By that I mean starting out with very little pressure on the thumb control is almost like going to WOT. This thing is going to be difficult to finesse over some steep rocky parts of the trail. Is a programmer what is needed to make the throttle response easier to manage?
Technoholic is offline
post #2 of 15 Old 02-04-2017, 10:36 PM
Hondatoy09's Avatar
Quoted: 4 Post(s)
I think that's one of the reasons a lot of people switch to a 13 tooth front sprocket to gear it down a little for trail riding.
Hondatoy09 is offline
post #3 of 15 Old 02-05-2017, 11:53 AM Thread Starter
Yea, I have read quite a few posts about 13 tooth front sprockets. I think that is worth a try and the cost is minimal. I thought about using a stiffer return spring also.
Am I the only one that dislikes this throttle? I mean the thing is more like an on/off switch than a throttle control. Were you able to adapt?
post #4 of 15 Old 02-05-2017, 12:03 PM
Quoted: 33 Post(s)
I had complainded about the touchy throttle in the past to. It is part of Honda's EFI system. The bike riders have the same issue. It's basically called fuel cut, for emissions.
Changing the sprocket will not help the throttle. Won't have to use the clutch as much in the tighter trails with the 13 tooth front sprocket.
I have a Dynojet programmer with the auto tune option and the throttle now works like it should have from the factory.
Luecker is offline
post #5 of 15 Old 02-05-2017, 12:28 PM
Quoted: 143 Post(s)
just wondering ,,, you running with the air box lid on or off?
cataway is offline
post #6 of 15 Old 02-05-2017, 03:30 PM Thread Starter
As for the engine I am running stock except for a UNI air filter and an exhaust header wrap. That is as far as I can tell not knowing the bike's history.
post #7 of 15 Old 02-05-2017, 03:37 PM Thread Starter
Looking at Power Commander WEB site, the Power Commander V is their current offering. Looks like a nice system specially with the O2 sensor option. Did you start out with the full boat system, or did you add Autotune afterward? I'm hoping it isnt necessary to spring for $700+ all at once.
post #8 of 15 Old 02-05-2017, 03:47 PM
Quoted: 143 Post(s)
ok,, how does it run with the box lid off?
cataway is offline
post #9 of 15 Old 02-05-2017, 07:12 PM
I agree the 13t won't help, if anything I'd think it would make it worse! Personally I never had a issue with the throttle. And you saying it's like a on off switch is puzzling. You mentioned a stiffer spring, does it not snap back on its own? I'm wondering if you may be better off with a twist throttle.
post #10 of 15 Old 02-05-2017, 10:46 PM Thread Starter
I have ridden with thumb throttles for many years so that familiarity is something I would like to keep. The thinking behind a stiffer spring was to maybe make it easier to control that first tiny bit of travel. Return is not an issue but the current spring is rather light making it very easy to hit way too much throttle.
