Clutch - Club700XX - Honda TRX700XX Forum
 1Likes
  • 1 Post By M_Quick
post #1 of 6 Old 02-06-2017, 12:16 AM Thread Starter
Anyone ever experience it not wanting to go into gear when you let off the clutch it kicks like it's in gear but doesn't move on its own power, after you Puch it in gear it kicks in after about 20 minutes of pushing. But if it sits for more than 5 minutes it needs pushed again. Is my clutch bad?
Dakota LaBine is offline
post #2 of 6 Old 02-06-2017, 04:08 PM
Have any oil in it? If clutch isn't bad, it soon will be from the way you describe it. Maybe do a oil & filter change, look for particles in the oil like clutch fibers.
post #3 of 6 Old 02-07-2017, 08:23 AM
Quoted: 144 Post(s)
replace the driver and the driven clutch disks
cataway is offline
post #4 of 6 Old 08-14-2018, 06:18 PM
After working on the clutch i was wondering does oil fill that chamber from the reservoir or is there a separate place i need to fill? Can anyone help answer?
Ryan Luera is offline
post #5 of 6 Old 08-14-2018, 06:52 PM
That's the only place you fill the oil, but certainly not the only place you drain it.
cataway likes this.
post #6 of 6 Old 08-16-2018, 05:40 AM
/CUDA's Avatar
Quoted: 27 Post(s)
The oil,
the same of the engine,
it lubricates the clutch, when you start the engine,
and when engine is on,
while when the engine is off,
the oil goes down.
/CUDA is offline
