Motor Vibration - This normal? - Club700XX - Honda TRX700XX Forum
 1Likes
post #1 of 16 Old 02-09-2017, 10:30 PM Thread Starter
Quoted: 5 Post(s)
I just picked up a 2008 700xx with 50 hours on it. Granted the tires need replacing and hold no traction. We just got a blizzard here and when I drive the quad at the higher RPMS i get motor vibration and the quad isn't going anywhere partially due to no traction.
This quad is so much different then my Polaris Scrambler 850 in the amount of Vibration.
I just want to know if this is normal
Kyle Lukas is offline
post #2 of 16 Old 02-09-2017, 10:33 PM Thread Starter
Quoted: 5 Post(s)
Also when would you know if the clutch is going bad?
post #3 of 16 Old 02-10-2017, 05:20 AM
Quoted: 142 Post(s)
I seam to remember a vibration before I did the +3 crank and +3 cylinder .infact I remember commenting on how much it surprised me that it was so smooth after the mod .
as for the clutch .................just do it . steels and fibers and deep six the judder spring and the odd fiber ring with the narrow facing .
cataway is offline
post #4 of 16 Old 02-10-2017, 09:07 PM
Quoted: 253 Post(s)
If theirs only 50 hrs on the quad, the clutch would of really had to be abused to need replaced. My original quad probably see's 50 hrs per session and the clutch is fine.
post #5 of 16 Old 02-10-2017, 09:10 PM
Quoted: 253 Post(s)
I just picked up a 2008 700xx with 50 hours on it. when I drive the quad at the higher RPMS i get motor vibration and the quad isn't going anywhere partially due to no traction.
Have you check the right inboard joint for play? That could cause high rpm vibrations. If I remember right, another user had a issue and only noticed when spinning tires a lot in the snow.
post #6 of 16 Old 02-11-2017, 02:07 AM Thread Starter
Quoted: 5 Post(s)
Yea so basically the vibration difference is the Large single motor, my scrambler 850 is a twin so there is very little vibration plus the seat is huge and thick to absorb any of it.
post #7 of 16 Old 02-11-2017, 03:35 PM
Quoted: 142 Post(s)
a 2008 700xx with 50 hours on it. its at least 8 years old ,that's 6.25 hours a year
cataway is offline
post #8 of 16 Old 02-11-2017, 10:09 PM Thread Starter
Quoted: 5 Post(s)
Lol, and? The quad basically sat for the last 2 years.
post #9 of 16 Old 02-12-2017, 01:38 PM
Quoted: 253 Post(s)
Exclamation
Update for math correction 8.33 hours per year!
Sounds like it needs a pretty good once over. I'd be greasing and lubing any and everything you can, to extend the life on the dry parts. Unless you think the guy that had it before did all this. I know there are a few sweet barn finds with little to no hours on these quads. A couple years ago someone sold one on here with (0) riding hours! Just purchased, upgraded and sat in the garage, only started and let idle once a month or so.
post #10 of 16 Old 02-12-2017, 03:22 PM Thread Starter
Quoted: 5 Post(s)
The original owner installed a hour clock on the quad from the dealer from day 1 so he could follow the maintenance schedule religiously. He was very anal. The quad is beyond clean.....
