Does anyone have a 400ex and 700xx, need a little help - Club700XX - Honda TRX700XX Forum
post #1 of 4 Old 03-21-2010, 02:54 AM Thread Starter
I was hoping someone owned both. Would you please check the pivot shaft thickness (outer diameter) on the male part of the rear brake pedal on the 400ex with a mic or dial caliper. Wanting to know if a billet shifter and/or billet brake pedal off 400ex will work on the xx, this thing needs a diet. Could you also take the 400 shifter and try to fit it on the 700 and see if the spline count is the same. It would be very helpful and much appreciated.
aceoutdoor is offline
post #2 of 4 Old 03-21-2010, 07:56 AM
ScottR's Avatar
I will try to do today.
2008 trx700xx
2006 trx400ex
2006 trx300ex (recovered)
2007 trx250ex
2006 trx250ex
2008 tt125
ScottR is offline
post #3 of 4 Old 03-22-2010, 06:38 PM
jamie007's Avatar
I have both also, would be good to know.
Jamie
2008 700xx - 23" Razr2's, Razrs, Flexx bars, Trail Tech clamp, ODI grips, Quad Tech desert seat, EHS EFI, EHS Lid, Uni filter, 13t
2000 400ex - DMC Double Barrel, FCR Carb
1987 250r (rip)
jamie007 is offline
post #4 of 4 Old 03-22-2010, 07:26 PM
From what I found the 700xx and 400ex share the same shaft diameter but would need modifying.
