engine stalling? - Club700XX - Honda TRX700XX Forum
post #1 of 6 Old 02-12-2017, 04:51 PM Thread Starter
xlarge7414's Avatar
Quoted: 7 Post(s)
engine stalling?
I had my engine stall on me a bunch of times today. Right after down shifting id go thru a turn and go to give gas and it would stall. Have any of you had problems like this? I did just put on a pipe and efi programmer, but i had this issue before that.
xlarge7414 is offline
post #2 of 6 Old 02-13-2017, 09:12 AM
700nathan's Avatar
First thing I would do, is check your spark plug. I'm not familiar with all programmer but I know on mine, I have to set low/mid/high
Sent from my XP7700 using Tapatalk
700nathan is offline
post #3 of 6 Old 02-13-2017, 12:26 PM
Last time mine stalled when slowing down to d/shift, well it never did re-fire until I replaced the ECM. I don't think this is the case with yours, since it's been doing it awhile. But like nathan said, check plug, and air filter, make sure you have fresh fuel too & dbl check the programmer settings. Does your quad stall out after a cold start, or any other times?
post #4 of 6 Old 02-13-2017, 08:07 PM Thread Starter
xlarge7414's Avatar
Quoted: 7 Post(s)
yes it stalls once or twice when cold now. before it stays running
post #5 of 6 Old 06-20-2017, 03:17 AM
Check your valves also. Maybe they are out of adjustment.
modrake is offline
post #6 of 6 Old 06-25-2017, 11:08 PM
its your program settings I can tell you my codes I had the same issue
Tomygunn1983 is offline
