Engine is apart, what "fun" parts do I replace? - Club700XX - Honda TRX700XX Forum
post #1 of 7 Old 02-13-2017, 07:56 AM Thread Starter
700nathan's Avatar
Hi all, this is my first post on this forum. I have been reading on this forum for a long time and I have learned lots. Thanks.
As my title says, my engine is apart (valve seals are shot). The cylinder wall looks good but I haven't really checked the rings yet. Other then that, I think everything is good.
While I have the motor opened up, I was thinking of a CP 11:1 piston, a webcams stage 2 cam and a good port and polish. Currently I have full HMF exhaust, K&N air filter and Wiesco fuel controller.
My question is, does this sound kinda logical or am I off on my plan?
Sent from my XP7700 using Tapatalk
700nathan is offline
post #2 of 7 Old 02-13-2017, 01:18 PM
Quoted: 252 Post(s)
Sounds like a plan, I'd change the valve guides as well. And you will need hard welded rockers for the web cam. Also on the piston you might wanna go +1 or +2 and then have your jug done at a local machine shop.
post #3 of 7 Old 02-13-2017, 01:45 PM Thread Starter
700nathan's Avatar
It's funny you say that. I'm meeting with a couple guys to discuss my options for cylinder and piston.
So it's true, webcam equals welded rockers?
post #4 of 7 Old 02-13-2017, 02:05 PM
Quoted: 141 Post(s)
you could do a +1 on the intake valves .
I believe I had R E do +1 on the intake valves on mine .what sold me was they use ferra valves . turn around was fast. I am almost happy with their work . I say that because I had RHC do the +1 valves on a different head ,a LTZ400. he did it the right way . i suspect if I ever pull the head I'll take the head to RHC and let him fix it .
cataway is offline
post #5 of 7 Old 02-13-2017, 03:11 PM
Quoted: 252 Post(s)
Yes
post #6 of 7 Old 02-14-2017, 12:54 PM
blakjak619's Avatar
Quoted: 34 Post(s)
Call Nate at Alba to get a smoking deal on their Big Bore Kit and might as well have them Port it.. I run their desert package with CP, Alba Port, Webcam, Hard Welded rockers, etc as its the most reliable setup for the xx...
blakjak619 is offline
post #7 of 7 Old 02-23-2017, 10:36 PM Thread Starter
700nathan's Avatar
Hey all, I've been away for awhile. I decided to go with a port/polish, 103mm 11:1 piston, stage two cam and some new valves. I would like to do more but my wallet won't let me. I'll let you know how it all works out
