Opinions needed - Club700XX - Honda TRX700XX Forum
 3Likes
post #1 of 23 Old 03-17-2017, 04:21 AM Thread Starter
Opinions needed
Hi, I'm a new member and a new owner on a trx 700 xx 2008. The quad is in very condition and some mods has been done to it but mainly on the body: flexxbars, trx 450r front shocks, grab bars, seat cover, all 4 wheels been changed (10 inchs on the back)and added spacers on the front. On the performance side, it has unifilter and a lexx mx slip on, no efi controller. I know the bike is factory lean and a fuel controller is nice to have even if not required with slip on. Now i have been reading these forums quite a bit and i totally understand that a big 3 upgrade from EHS would add alot to the bike, but i was wondering what if i just buy a fuel controller, either from lexx or EHS, would that be a good move, money wise, considering i'm already running a slip on? Or I should just go with the EHS big 3?
My point here being I dont mind spending 900 bucks on the Big 3 upgrade. I know its worth the money but I also wanna consider that a 210 bucks EHS controller (and lexx is 169$ at rocky mountain atm) would help the quad with performance with little cost. I'm a trail rider and I also just want the bike to run good. Lots of people with experience here and I'm asking for your opinions.
Thanks.
700xxPat is offline
post #2 of 23 Old 03-19-2017, 11:34 AM
Quoted: 144 Post(s)
Barker pipe
yes get a fuel controller
cataway is offline
post #3 of 23 Old 03-19-2017, 03:40 PM
I'm confused a bit, do you all ready have the slip on pipe or not? If you do, then just add a programmer. If your wanting to know if a full exhaust is better than a slip on, of course it is. If wanting to up grade the exhaust, I'd look at the HMF Black out! I have the Barkers and the HMF and personally like the HMF better. The new HMF black out series offers a ceramic coated header. Price that on the Barkers!
post #4 of 23 Old 03-20-2017, 12:21 PM
Yes I do already have the slip on. My question was if it was worth it, as in will I really see a performance increase considering the cost, to get the big 3 vs just adding a fuel controller to my current set up? But after thinking about it long enough I finally decided to get EHS big 3 package, figured if I gotta do it, might as well do it right the first time around.
09RappySE likes this.
700xxPatt is offline
post #5 of 23 Old 03-20-2017, 06:45 PM
The average increase is around 10% hp over stock.
post #6 of 23 Old 03-22-2017, 07:15 AM
Quoted: 144 Post(s)
sure if that's all you are ever going to do to it .one of my other quads is a ltz400 ,I did a little here a little there knowing full well I would never be happy till I had done every thing I could do . should of done every thing from the getgo its now about 60hp . but when I look back at all I spent just on head gaskets and cam's getting to were it is now ,I shake my head in disbelief .
if you think your going to do , do it.
cataway is offline
post #7 of 23 Old 03-22-2017, 01:45 PM
Yes that's all I will ever do to it, to the engine anyway. Modding gets so expensive that to me, it's not worth it that much. I just want the quad to run good without being choked up. I might try to get bigger sway bar later on, and 13t front sprocket if necessary but where I ride it's mostly fire roads, very little tight trails so speed is important.
Thanks for the comments!
post #8 of 23 Old 03-23-2017, 05:40 PM
I'd stick with the 14t if I was you. Clutch is cheaper than engine parts.
post #9 of 23 Old 01-30-2018, 10:43 AM
I am thinking of getting the big 3 kit. But what's better power coated or ceramic. And vents in the box or none?
wiseguy8536 is offline
post #10 of 23 Old 01-30-2018, 01:25 PM
Ceramic coating is usually just done to the header, and the mufflers are powder coated. And yes to vents, to let it breathe. EHS Racing makes a nice air box lid. Or you can make your own if your able. Check out HMF's ceramic coated black out exhaust.
