Rebuild question - Club700XX - Honda TRX700XX Forum
post #1 of 12 Old 03-31-2017, 12:23 AM Thread Starter
g-low's Avatar
Quoted: 4 Post(s)
Rebuild question
I just finished replacing the valve seals on my TRX 700. I was going through some heat cycles for the break in and I'm not sure if it sounds right. I was wanting someone with a more experienced ear to let me know what they think. How do I attach a video?
Furthermore, the muffler pipe gets real hot very fast during this cycle. I was wondering if this is normal for a break in?
g-low is offline
post #2 of 12 Old 03-31-2017, 08:29 AM Thread Starter
g-low's Avatar
Quoted: 4 Post(s)
g-low is offline
post #3 of 12 Old 03-31-2017, 12:37 PM
Quoted: 142 Post(s)
did the Cam chain tensioner get bumped out to the chain ?
cataway is online now
post #4 of 12 Old 03-31-2017, 02:11 PM Thread Starter
g-low's Avatar
Quoted: 4 Post(s)
I'm not sure how to tell if it has or not. When I reinstalled it I used a small screwdriver and screwed it back so I could get the bolts in then I pulled the screwdriver out. I thought it automatically when back forward when I removed the screwdriver.
g-low is offline
post #5 of 12 Old 03-31-2017, 03:06 PM
Quoted: 142 Post(s)
it would be easy to check
post #6 of 12 Old 03-31-2017, 03:31 PM Thread Starter
g-low's Avatar
Quoted: 4 Post(s)
Should I just take the tensioner out and see if it is still stuck back?
g-low is offline
post #7 of 12 Old 03-31-2017, 03:41 PM
Quoted: 142 Post(s)
use a screwdriver , see if turns in or out
post #8 of 12 Old 04-01-2017, 01:33 PM Thread Starter
g-low's Avatar
Quoted: 4 Post(s)
I think my cam chain tensioner is shot. I pulled the valve cover to recheck the timing and I was able to see that my tensioner was out and against the guides for the chain. But when I screwed back to adjust the chain on the sprocket, I released it and it didn't go all the way forward. I had to turn it counterclockwise a few turns for it to come all the way out.
g-low is offline
post #9 of 12 Old 04-01-2017, 06:10 PM
Quoted: 142 Post(s)
all the way out ?
post #10 of 12 Old 04-03-2017, 12:45 PM Thread Starter
g-low's Avatar
Quoted: 4 Post(s)
I found out the piece I am speaking of is called the tensioner lifter. It doesn't come all the way out to put the proper pressure on the tensioner.
g-low is offline
