Adjusting Clutch & Valves - Club700XX - Honda TRX700XX Forum
post #1 of 9 Old 03-30-2010, 09:22 PM Thread Starter
ChadH67's Avatar
Send a message via Yahoo to ChadH67
Is there anyone out there who might be able to help me out with adjusting my clutch and setting my valve's?
ChadH67 is offline
post #2 of 9 Old 03-30-2010, 10:11 PM
Look in the manual down load for the valves. The hardest part is just getting to them. Took me about hour or hour and a half the first time.
500Rubie is offline
post #3 of 9 Old 03-30-2010, 10:34 PM Thread Starter
ChadH67's Avatar
Thanks yeah I actually just downloaded it plus Phucknutz gave me a quick run down, Thanks tho
ChadH67 is offline
post #4 of 9 Old 11-16-2010, 11:54 AM
So I find myself a pretty damn good mechanic, put several upgrades in motors but never on wheelers, I adjusted my valves myself with the correct tolerances and put everything back together and started it up and it sounds like I have a rocker tick, does this go away?
I'm pretty sure I set the piston to top dead center correctly and used the correct feeler gauges .006 on intake and .008 on exhaust. Maybe let it heat up and I'm thinking it'll go away in time too, any help would be greatly appreciated.
JTREB is offline
post #5 of 9 Old 11-16-2010, 09:16 PM
Was the bike cold when you set them? Although it would make them tighter if it was warm.
Did it tick before? Did you check and see what they were before you adjusted them.
I hear a noise every time I work on something, wrenchin paranoia will make you second guess yourself.
post #6 of 9 Old 11-16-2010, 09:37 PM
USMC0861's Avatar
Me too
USMC0861 is offline
post #7 of 9 Old 11-16-2010, 11:06 PM
The bike was cold, i didn't let it warm up yet after adjusting the valves. The intake was a tight .004, and the exhaust was a tight .006, now they're set with a very slight drag on proper tolerances, i'm going to check them again and make sure they're fine, then let put it together and let it warm up.
JTREB is offline
post #8 of 9 Old 11-17-2010, 09:27 PM
scrawny's Avatar
the tick means there is clearence. if they were tight there was no noise and you were used to that?
08 700xx
05 Ruckus
04 450r
86 Fat Cat
86 350x
81 250r
72 CB100
scrawny is offline
post #9 of 9 Old 11-19-2010, 10:47 AM
So I decided to go back in and found i messed up one of the valves on the exhaust side, it was at about .010, no idea how i did it, must of forgot to check it after i torqued it.
JTREB is offline
