velocity vs uni - Club700XX - Honda TRX700XX Forum
post #1 of 12 Old 03-30-2010, 09:51 PM Thread Starter
velocity vs uni
which gives more air and power with ehs lid
tomtalbot10589 is offline
post #2 of 12 Old 03-30-2010, 10:00 PM
vfm2010's Avatar
A paper filter(K&N,Velocity) will flow air more freely and give more power but a foam filter will offer better filtration protecting your motor better.
88 LT500R QUADZILLA
06 DVX400 (Son's)
06 TRX250EX (Wife's)
vfm2010 is offline
post #3 of 12 Old 03-31-2010, 03:51 PM
xx-rated's Avatar
You'll find that most people really lean one way or the other. The guys that like foam swear that paper/gauze filters like the K&N and Velocity suck. The Uni will definitely offer you better protection. I have a Velocity and run a pre-filter. I have yet to find any dust in the intake. I like K&N and Velocity because I HATE cleaning foam filters. I've had good experience with K&N too, so I went that route. If you ride in a lot of dust, then I would probably go with a foam filter like the Uni.
xx-rated is offline
post #4 of 12 Old 03-31-2010, 04:12 PM
Agree with xx-rated. The K&N are not paper though, they are made of pressed cotton fiber.
2006 Raptor 700
post #5 of 12 Old 03-31-2010, 07:05 PM
warlock28's Avatar
Yup, depends on where you ride. I have the UNI and ride mostly in the desert.
2008 TRX700xx X 2
2003 Excursion V10 (Pull Toy)
warlock28 is offline
post #6 of 12 Old 03-31-2010, 07:47 PM
I have run both on different bikes over the years. I think the K&N type filters will flow somewhat more but I question if they are as good at filtration as the foam filters. I have no proof of that, and you can find opinions either way all over the net.
Both are good as long as you keep them clean and maintain them per the manufacturers recommendations.
If you use some type of pre-filtering method, the time between cleanings will be similiar. The K&N type filters are much easier to clean though.
It really comes down to personal preference. I run a UNI on my 700XX.
post #7 of 12 Old 04-01-2010, 06:16 AM
Shovelhead's Avatar
OK, I have question for you.. i have the EHS Airbox lid & I have the K&N with a prefilter also..I want to know if I have too much restriction on air flow by using 2 prefiltered devices??
Shovelhead is offline
post #8 of 12 Old 04-01-2010, 10:22 AM
xx-rated's Avatar
Absolutely not.
xx-rated is offline
post #9 of 12 Old 04-01-2010, 11:13 AM
Shovelhead's Avatar
Thanks xx-rated..
post #10 of 12 Old 04-03-2010, 04:09 PM
Outlwd's Avatar
I have K&N on my truck, other quads, and my car. Cleaning them is a snap and like stated already if it's real dusty just use a prefilter and all should be fine.
Outlwd is offline
