Easiest way to replace CV boots - Page 5 - Club700XX - Honda TRX700XX Forum
 1Likes
post #41 of 45 Old 03-28-2018, 09:38 AM Thread Starter
Quoted: 36 Post(s)
Originally Posted by jvs1670 View Post
Mine just started clicking on the right rear too. Did you guys just keep riding anyway? I'm about to go to Moab in a few weeks. What parts would I need if I decided to try and fix it?
Hard to find a ton of info, should've know better than to buy a discontinued machine. Sucks
I think youíll be fine to keep riding it. I left mine with the clicking noise and nothing bad happened there. Iím gonna try changing out the wheel hub bearing to see if that solves the issue.
Kubi07 is offline
post #42 of 45 Old 03-29-2018, 06:26 PM
I ripped a boot open on my 2nd ride when I got mine, no idea how. if you catch it early, you just need to repack and replace the boot. A honda boot kit includes both boots for a side. If you let it go then you may need to replace some other stuff too. You will have to get it apart to see.
It is PITA to change the left (from the riders position) axle or boots because the right has to come off first. You need a 46mm socket for the center hub. You can get it Northern tools or a place like that along with a 3/4 drive adapter. Pay a few dollars for the socket, do not try the hard way. You also want some extra hands when you put the stainless clamps on the new boots. You have to stretch and bend these as you clamp down.
XSmojo is offline
post #43 of 45 Old 04-03-2018, 05:00 PM Thread Starter
Quoted: 36 Post(s)
Couldn't even separate the axles to get to the 46mm nut for the hub
Kubi07 is offline
post #44 of 45 Old 05-14-2018, 02:33 PM
Well I'll try and clean and grease it 1st. The boot looks ok but maybe dirt got in there somehow or it's just really dry.
jvs1670 is offline
post #45 of 45 Old 05-14-2018, 02:47 PM
Originally Posted by cataway View Post
your thinking that if they still made them yours would not ware out
Yea good point, guess that doesn't make sense. It's worth fixing for sure this thing is fun to ride.
jvs1670 is offline
