going dead just with slightest touch of throttle? - Page 2 - Club700XX - Honda TRX700XX Forum
post #11 of 13 Old 05-07-2010, 08:06 PM
maybe that can explain why mine does that and why sometimes she wont start up, like at my race last weekend.
post #12 of 13 Old 05-09-2010, 04:28 AM
So I was looking in the manual and everything, and I don't see anywhere in there that says how to do this? Anyone going to write it up? Also Joe, I looked up those parts, could only find one on the fiche...blaming this all on nikki cuz she is talking to me LOL
post #13 of 13 Old 05-09-2010, 09:31 AM
Chuck
It's on page 6-30 and 6-37 in the manual. The first part tells you how to relief the pressure on the pump line and the latter page tells you how to remove the pump. As for taken the pump apart, there are no instructions since they tell you not to take it apart but as long as you have those parts listed above, you just need to remove those bolts and pull the pump apart then replace the filter and O rings. The filter is a PIB to remove but it will come off, can't remember how to.
