going dead just with slightest touch of throttle? - Club700XX - Honda TRX700XX Forum
post #1 of 13 Old 04-04-2010, 09:55 PM Thread Starter
Send a message via Yahoo to coolkev25
if u having this problem, and had ur xx for some time, u might wanna change fuel filter in ur fuel pump! its only 17 bucks, and six screws i think. its easy, not hard to replace.
coolkev25 is offline
post #2 of 13 Old 04-06-2010, 12:03 PM
Well if you have small hands, it's not hard to remove especially one of the bottom quick disconnect, talk about being a PIA.
post #3 of 13 Old 04-06-2010, 12:22 PM
Would you like to post a how to on How to in the How to section? :-P
post #4 of 13 Old 04-11-2010, 09:57 PM
Im having those exact problems so ya if u post an how to id appreciate that.
Dmtz SSlaclinc is offline
post #5 of 13 Old 05-06-2010, 06:34 PM
Do you have a part number or where you got the pump filter from as mine needs changing .
post #6 of 13 Old 05-06-2010, 06:40 PM Thread Starter
Got it at a dealer! Same filter they use on one them cruiser bikes! Can't remember number tho! Its a my shop tho!
post #7 of 13 Old 05-06-2010, 06:41 PM Thread Starter
gas filter
post #8 of 13 Old 05-06-2010, 06:44 PM
What breed of cruiser , then I will find it.
post #9 of 13 Old 05-06-2010, 06:59 PM
Lee
Here's the info;
1 of 16706-HN8-A62 - FILTER SET (Honda Code 9181157) @ $10.31ea.
1 of 16955-HP6-A00 - TUBE, FUEL (Honda Code 8960908) @ $13.51ea.
2 of 91351-881-000 - O-RING (66MM) (Honda Code 0499533) @ $3.30ea.
http://www.powersportspro.com/pages/...d/7/Honda.aspx
post #10 of 13 Old 05-06-2010, 07:04 PM
Cheers ace .
