What parts to replace during bottom end build? - Club700XX - Honda TRX700XX Forum
post #1 of 5 Old 07-24-2017, 11:35 AM Thread Starter
Quoted: 33 Post(s)
Ok so I am splitting the cases to add a 3mm stroker crank. I am going to replace all the bearings in the cases and transmission. Anything else recommended to replace like the balancer shaft, shift forks, etc?
Luecker is offline
post #2 of 5 Old 07-24-2017, 01:51 PM
blakjak619's Avatar
Quoted: 35 Post(s)
Not sure on the exact parts list but if you have some extra coin you should all of your engine parts cryo and micropolished. Smooth as butter and extends engine life considerably.
blakjak619 is offline
post #3 of 5 Old 07-24-2017, 02:22 PM Thread Starter
Quoted: 33 Post(s)
Did you have cryoheat in San Diego do yours?
Luecker is offline
post #4 of 5 Old 07-26-2017, 05:03 PM
Quoted: 143 Post(s)
timing chain and look at the oil pump , any marks on it ...........replace it.
on the cam ,note the seal on the one bearing .....make sure it gets back in the same place
cataway is offline
post #5 of 5 Old 07-27-2017, 04:26 PM
blakjak619's Avatar
Quoted: 35 Post(s)
The guys at CryoHeat did our other bike and will be doing mine next time I rebuild most likely in the spring
