Stock vs. Big Gun header - Page 2 - Club700XX - Honda TRX700XX Forum
post #11 of 16 Old 08-30-2017, 06:05 PM
Quoted: 224 Post(s)
Originally Posted by Wreckless_Rider View Post
Havent checked out the the HMF much, going to give eric @EHS a call tomorrow.
The HMF Black out Series link below. Simply put it's Bad Ass & ceramic coated!
https://www.hmfracing.com/blackout
A eBay seller sold one for as low as $515.00
post #12 of 16 Old 09-01-2017, 08:31 AM
Quoted: 55 Post(s)
If you happen to ever see that again, let us know! I still don't know if I could spend that much for an exhaust (especially since I'd need a tuner as well), but if I spent ANY money on one, I definitely would want the blackout!
mumbauer is offline
post #13 of 16 Old 09-01-2017, 01:38 PM
Quoted: 224 Post(s)
Same seller I purchased my original HMF exhaust. The guy is very good at best offer options, I forget how low I got him on mine. Here's link just click on where it shows (5 sold) and it will show you the purchase price history.
Honda TRX 700XX 08-09 HMF Performance Full Blackout Series Exhaust 019404608892 | eBay
post #14 of 16 Old 09-01-2017, 04:25 PM Thread Starter
Quoted: 7 Post(s)
Whats so special about the blackout? Just the looks?
Wreckless_Rider is offline
post #15 of 16 Old 09-01-2017, 10:53 PM
Quoted: 224 Post(s)
Yeah that's about it! And the fact that it has what HMF calls "Cerakote" (Sara-coat-ing) a high Temperature Ceramic coating capable of withstanding 1200 degrees. Well worth the extra $15 to $25 over the other pipes @$500. Just ask what Sparks or EHS charges just to coat there header. And the Black out has a completely coated head pipe, inlet and end cap with a high temperature ceramic coating that increases impact strength while increasing resistance to abrasion, corrosion, and chemicals. The exhaust will/should look great for years, instead of after a few hours they turn colors on the header, then rust. Also the ceramic coating will help some with heat.
post #16 of 16 Old 01-18-2018, 02:23 PM
Quoted: 8 Post(s)
what the difference between big gun and powerbomb head pipe, and will either work with a lexx slip on?
itsamemario834 is offline
