pops and stalls - Club700XX - Honda TRX700XX Forum
post #1 of 12 Old 04-10-2010, 06:24 PM Thread Starter
markas214's Avatar
pops and stalls
Not often but since I've gotten it I'll be pulling out and I get a pop and it dies out. Then it needs a few cranks to restart. In fact it never turns right over when I start it like my EFI cars. Is that normal? I put my FMF programmer on and same thing. I'm thinking a bad module somewhere. When I take it for warranty repair should I remove my UNI and programmer. I have the FMF Powerbomb and 4.1 ready to install but will wait if people believe I have a defective part that needs the dealer to check for.
Renthal 13 tooth sprocket
Alba Pro Elite nerf bars
CCP steering damper
L8ton Racing 9/16 Swaybar
Teixeira upper a-arms
Powermadd handguards
markas214 is offline
post #2 of 12 Old 04-10-2010, 06:44 PM
droby1242's Avatar
did you use premium or regular fuel?????
droby1242 is offline
post #3 of 12 Old 04-10-2010, 06:48 PM
Mine does that too if I don't give enough gas and slip the clutch a little when I take off or any time I'm in too high of gear without enough rpms. And mine also cranks a few times before it starts.
carlstoys is offline
post #4 of 12 Old 04-10-2010, 06:50 PM
When was the last time you changed/checked your plug?
Mine was doing that before I changed it.
post #5 of 12 Old 04-10-2010, 06:51 PM
skier207's Avatar
Mine does the same thing. Operator malfunction in my case. Takes a few cranks to get a restart.
skier207 is offline
post #6 of 12 Old 04-10-2010, 09:17 PM
When you restart it, is it right afterwards? And are you touching the gas at all. I know one of my friends has a EFI KAWI, and didn't realize that you can't hit the gas while trying to start like you do on some carbed machines.
post #7 of 12 Old 04-10-2010, 10:05 PM
Tory trx's Avatar
Mine did it for a while but after brake in it runs like a raped ape with no problems at all. I think it is just an adjustment period where the bike learns how to adjust to your riding. It is a fuel injected bike and the computer will learn how to run properly. How long have you had it?
Tory trx is offline
post #8 of 12 Old 04-10-2010, 10:08 PM Thread Starter
markas214's Avatar
Sounds like a good first step. Cheap and simple is always the best way to start trouble shooting. I went ahead and put my Powerbomb and Factory 4.1 muffler on, set the programmer a bit richer and so far OK but still a good idea to change the plug. That way I can do the color check.
HOLY SHIT! The XX is like a rocket now.
I know about keeping off the gas. I use premium always. I'll see what happens now I have the exhaust and UNI filter. I'll try these settings and see what happens tomorrow. I'm taking it to the MX track. Thanks for the input and more welcome.
CCP steering damper
post #9 of 12 Old 04-10-2010, 10:15 PM
You're welcome.
It's also been my experience that when it's rich it's harder to start than when it's lean.
post #10 of 12 Old 04-10-2010, 11:12 PM
VelociRaptor's Avatar
Usually when you have starting problems with a lean condition it wont fire up at all or it will cut off soon after firing up.
Bo White
205-886-7043
VelociRaptor is offline
