Broken crankcase, can I fix it myself? - Page 10 - Club700XX - Honda TRX700XX Forum
 3Likes
post #91 of 151 Old 01-25-2018, 08:27 PM
Don't set oven at 300! Read the manual!
post #92 of 151 Old 01-25-2018, 09:07 PM
Quoted: 144 Post(s)
Originally Posted by Kubi07 View Post
How would I go about putting it on while reassembling? Don't wanna get to the point that I have to cut it again lol.
its really very easy . there is a pic on 13-16 just put the chain on the sprocket and sprocket on to the shaft , that's all you really need to do with the chain till the cylinder is ready to go on
cataway is offline
post #93 of 151 Old 01-26-2018, 09:25 AM Thread Starter
Quoted: 36 Post(s)
And when it comes to rebuilding the head, should I go with OEM or Kibblewhite? Or are there any others out there?
Kubi07 is offline
post #94 of 151 Old 01-26-2018, 05:15 PM
Quoted: 144 Post(s)
you going to do a +1 on the intakes ? any head work ?
cataway is offline
post #95 of 151 Old 01-26-2018, 05:24 PM
Quoted: 144 Post(s)
the very best valve you can get is offered from RHC
cataway is offline
post #96 of 151 Old 01-26-2018, 07:03 PM Thread Starter
Quoted: 36 Post(s)
How would I go about getting head work? Take it to a shop right? And if I don't do head work, it doesn't make sense to go +1 I'm guessing? And I'll look into RHC, haven't heard of them but the kibblewhites are so much more expensive than OEM.
Also, I got the valves out and see that all my guides are broken and all the valves are bent... Gonna stick it in the oven, I really hope I can get them out.
Kubi07 is offline
post #97 of 151 Old 01-26-2018, 10:39 PM
Quoted: 144 Post(s)
if it were mine the head would go in a box and off to RHC
cataway is offline
post #98 of 151 Old 01-27-2018, 08:54 AM Thread Starter
Quoted: 36 Post(s)
How much would it be for the port work?
Kubi07 is offline
post #99 of 151 Old 01-27-2018, 10:48 AM
Quoted: 144 Post(s)
ask Ron Ron Hamp Cycle
cataway is offline
post #100 of 151 Old 01-29-2018, 04:19 PM Thread Starter
Quoted: 36 Post(s)
If I port it, do you think I should go with the +1mm valve too?
Kubi07 is offline
