XX likes to stall at low rpm speeds, starts normal, idles fine. - Page 2 - Club700XX - Honda TRX700XX Forum
post #11 of 13 Old 05-02-2018, 09:22 PM
Quoted: 242 Post(s)
I always thought popping or backfire on deceleration, was from to much fuel UN-burnt fuel that reaches the hot exhaust.. Have you changed your spark plug? I run the NGK platinum laser plug in mine.BKRGEKPB-11 3452
Try easing off the throttle instead of just all the way off at once. And I'd put on a 14t front asap if I was you.
post #12 of 13 Old 05-03-2018, 06:03 AM
Footy's Avatar
Quoted: 38 Post(s)
I just put in a new NGK plug but I do not remember the number. The dealer had to order it so I know it was not a regular plug.
Why do you recommend the larger front sprocket?
2017 Honda TRX500 Rubicon
2013 Husaberg FE350
2008 Honda TRX700XX
1995 Honda TRX 300EX
2001 Honda TRX 90
1986 Honda TRX 70
1985 ATC 250 SX
Footy is offline
post #13 of 13 Old 05-03-2018, 04:06 PM
Quoted: 242 Post(s)
Easier on the motor, and with your mods you shouldn't need the 13t like a stock 700xx.
