motors out and split - Page 2 - Club700XX - Honda TRX700XX Forum
post #11 of 22 Old 01-27-2018, 09:34 AM
Originally Posted by cataway View Post
there is a oil mod I'm thinking of doing . it will put more oil directly onto the cam lobes and I'm considering plugging the hole that's in the end of the cam shaft ,
Sounds interesting, maybe if you have the time you could post a how to thread, with pictures and explanations.
post #12 of 22 Old 01-27-2018, 10:38 AM Thread Starter
Quoted: 143 Post(s)
i'd like to post pic's but i have a hard time giving photo bucket $300 for the privilege.
it consists of running a external line from a oil pressure point, to the top of valve cover ,directly over and squirting onto the cam lobe . the oil psi is rather low on the xx ,something like 5 psi . its more of a high volume of oil then high psi thing . I'm thinking the place to pickup the oil is in the center of the oil filter cover . or could tap-in off center of the cap and pickup un-filtered oil .
cataway is offline
post #13 of 22 Old 01-27-2018, 08:04 PM Thread Starter
Quoted: 143 Post(s)
i was looking in to the intake of the head , i had done some clean-up of the ports when i installed the big bore . and i thought to my self i could do better .soooooo................ i did .
waiting for stronger clutch springs and the RHC cam.
i would like to move the TB a bit farther away from the head , no more than an inch . If i can find a straight boot. one with both ends the same size . fits on to the TB ,then a short pipe spacer to fill in the space to the head boot .
your thinking ....why ?
cataway is offline
post #14 of 22 Old 01-28-2018, 06:19 PM
Quoted: 33 Post(s)
[QUOTE=cataway;239705]i'd like to post pic's but i have a hard time giving photo bucket $300 for the privilege.
Try postimage.org
Luecker is offline
post #15 of 22 Old 01-29-2018, 09:11 AM Thread Starter
Quoted: 143 Post(s)
[IMG][/IMG]
testing . can you see pic ?
cataway is offline
post #16 of 22 Old 01-29-2018, 10:40 AM
Quoted: 62 Post(s)
I see it
mumbauer is offline
post #17 of 22 Old 02-04-2018, 08:50 AM Thread Starter
Quoted: 143 Post(s)
motor is back in frame .
wow, with out a overhead lift that would of never happen . the lift table helped to .
yet,...... still waiting for parts . hard to say when the new cam will come, even so ,it may be March-April till i will want to get out and ride.
cataway is offline
post #18 of 22 Old 02-07-2018, 04:22 PM
Sounds like the Fourstroke Tech oil cooler kit they build for the 400ex. I have fitted one to my 400ex and thought about doing the same to the 700xx. Contacted them and they said they have never tried it on a 700xx.There is a strainer/restrictor in the head gasket. I am probably just going to put a oil cooler on the return line.
Also wish I'd seen this post sooner , so I could advise you on some other parts to check closely for the jumping gears in the gearbox.
I tend to change shifter shaft , shift drum , shift fork and one gear in the transmission. Currently on transmission number 4 and trying a Rekluse 450r slipper clutch to cure the problem. Don't think it is a problem with the gearbox , more the way I ride/abuse the 700xx.
post #19 of 22 Old 02-08-2018, 08:37 AM Thread Starter
Quoted: 143 Post(s)
other than the center fork i did not find any thing wrong in the trans.
cataway is offline
post #20 of 22 Old 02-10-2018, 09:28 PM Thread Starter
Quoted: 143 Post(s)
this is where i tied into the oil circuit. seamed like the obvious place. 12mm 1. thread
cataway is offline
