Cooling fan help/question - Club700XX - Honda TRX700XX Forum
 1Likes
  • 1 Post By M_Quick
post #1 of 7 Old 04-27-2018, 06:48 PM Thread Starter
My motor overheats, has anyone or does anyone know how to wire in a toggle switch to run the fan whenever you want it to run.I'm talking about eliminating the stock control of the fan,and basically running the fan full time once the engine is running via toggle switch. My 450R is on a simple growing set-up and i just have it on full time. 700xx needs a different set-up, toggle switch style for after the Estart gets her heart pumping
throttlextrem111 is offline
post #2 of 7 Old 04-27-2018, 08:11 PM
Quoted: 143 Post(s)
yes it can be done
cataway is offline
post #3 of 7 Old 04-27-2018, 09:42 PM
Originally Posted by cataway View Post
yes it can be done
Yeah but I think the issue needs addressed, I wouldn't just apply a band aid.
09RappySE likes this.
post #4 of 7 Old 04-28-2018, 08:27 AM
Quoted: 143 Post(s)
maybe ,maybe not . i my self feel the fan should come on much earlier than it does
cataway is offline
post #5 of 7 Old 04-29-2018, 06:30 AM Thread Starter
Of course I plan to address the fresh top end it needs, but for now I simply want to want to bbtbe able to switch the fan on whenever it's up to operating temp to keep it cool as possible. I was hoping someone knew which wire to tap into with a toggle switch.
On my trx450R ts a simple ground wire,the 700xx is still a mystery to me.I'd rather not fry anything experimenting
post #6 of 7 Old 04-29-2018, 07:59 PM
Quoted: 143 Post(s)
if memory is right ,unplug the wire on the left side . fan should come on
cataway is offline
post #7 of 7 Old 05-03-2018, 07:01 PM
I put a regular On/Off switch on mine and is very easy. Just peel the positive wire of the fan and connected to one side of the On/Off switch. Take the other wire on the switch and connected to the positive on the battery. And you’re ready. The good thing about it is that the temperature light wich is red, stays functional. Hope it help you.
jayjay1 is offline
