Power for front LED running lights - Club700XX - Honda TRX700XX Forum
post #1 of 2 Old 05-26-2018, 08:37 PM Thread Starter
I am adding front LED running lights. Where is the best place to get power that is turned on when the key is turned on?
I have already added two connections directly to the battery, one of a power commander and one for the Trail Tech.
Really don't want to add a switch to turn the lights on if I can avoid it.
Is there anywhere upfront I could tap power from. The LEDs don't draw a lot of power.
Thanks in advance.
Merle
machenmusic is offline
post #2 of 2 Old 05-27-2018, 07:43 PM
Quoted: 252 Post(s)
Idk why you would want to run a led without a switch, but I'm glad I don't ride where you ride! I would be PO if someone coming the opposite direction as me and left there led light's on at night time. Why would you want them running in the daytime as well?
I would run them with a wiring harness. They come with a relay, inline fuse, and a switch. But if you wanna wire them hot with key on, tap into your trail tech, and ground where ever.
