Strange metallic noise - Club700XX - Honda TRX700XX Forum
 3Likes
  • 1 Post By M_Quick
  • 1 Post By /CUDA
  • 1 Post By M_Quick
post #1 of 10 Old 05-28-2018, 10:51 AM Thread Starter
/CUDA's Avatar
Quoted: 27 Post(s)
Hello guys,
I write from Italy,
my english, not too good.
I write for your help,
I have a trx700xx 2009
performance, very good, 134 km / h
My problem"
It is a strange rattle,
when I'm in dirt road,
accelerating very strong.
It does not always happen, but often.
It looks like a metallic vibration,
but I do not understand which part,
do you have a similar noise?
/CUDA is offline
post #2 of 10 Old 05-28-2018, 11:10 AM
Either the valves, or loose heat shield on header?
09RappySE likes this.
post #3 of 10 Old 05-28-2018, 11:16 AM Thread Starter
/CUDA's Avatar
Quoted: 27 Post(s)
Thanks man,
I will check, heat shield,
valves I do not think,
I hear this noise, only when I am full of vibrations,
for road, extremely irregular,
stones, holes
and accelerating a lot.
Thanks again!
/CUDA is offline
post #4 of 10 Old 05-29-2018, 09:24 AM
Quoted: 62 Post(s)
Or aftermarket skid plate, when I added mine I was surprised how much it rattles.
mumbauer is offline
post #5 of 10 Old 05-29-2018, 10:31 PM
I've not had a problem with my skid plates. they both came with foam. Now the front a-arm guards did rattle, until I replaced with prm guards. Also my license plate on the one quad buzzes.
post #6 of 10 Old 05-30-2018, 06:14 AM
Footy's Avatar
Quoted: 46 Post(s)
I have a strange buzz on mine too. I have not found the bad actor yet. I was guessing a heat shield.
2017 Honda TRX500 Rubicon
2013 Husaberg FE350
2008 Honda TRX700XX
1995 Honda TRX 300EX
2001 Honda TRX 90
1986 Honda TRX 70
1985 ATC 250 SX
Footy is offline
post #7 of 10 Old 05-30-2018, 08:22 AM
Quoted: 62 Post(s)
I didn't get foam with mine and I haven't taken the time to take it apart and back together...I really should though as the rattle is quite noticeable.
mumbauer is offline
post #8 of 10 Old 05-30-2018, 09:07 AM Thread Starter
/CUDA's Avatar
Quoted: 27 Post(s)
Thanks for the answers guys,
I removed the protective shield, magnesium color,
but I see that there is also a black shield, which goes to the muffler,
that I will have to remove,
in the weekend.
If without them, noise disappears,
I think of solving
with this,
between the pipe and the shield
it should also help for the heat,
protection in the right leg,
being glass fiber specific, for this use
M_Quick likes this.
/CUDA is offline
post #9 of 10 Old 06-04-2018, 10:13 AM Thread Starter
/CUDA's Avatar
Quoted: 27 Post(s)
Hello,
yes, the rattle cause are the two heat shields,
/CUDA is offline
post #10 of 10 Old 06-04-2018, 03:22 PM
Originally Posted by /CUDA View Post
Hello,
Good deal, I know those squeaks and rattles can be real annoying, until you figure them out.
/CUDA likes this.
