Low hour all original 700XX high speed stalling - Club700XX - Honda TRX700XX Forum
post #1 of 24 Old 06-16-2018, 12:45 PM Thread Starter
I have a all original and totally stock 2008 700XX with maybe 50hrs on it. I normally just get it out from time to time just to get on blacktop and do some full throttle top speed riding. A few weeks ago I noticed as I was full throttle nearing top speed the bike cut out like was out of fuel then took right back off like nothing ever happened. Well I've had it out a few times since then and it has happened most other times as well. I have ran it out of fuel before at top speed and have it cut out until I reach down and flip it to reserve then it be right back to normal. What the bike is doing now acts just like that but with a a full tank of fuel and makes no difference if fuel is turned to on or reserve position. Other than it cutting out at times during High speed riding like it starved for fuel for a second or two it goes right back to running like normal. It starts idles and runs like new until those top speed runs or hard pulls getting up to top speed. Any idea what's going on with my bike? Thanks
Joe Wilder is offline
post #2 of 24 Old 06-19-2018, 09:37 AM
Quoted: 62 Post(s)
I can't imagine it would be the fuel filter, but wouldn't hurt to check it.
mumbauer is offline
post #3 of 24 Old 06-22-2018, 07:15 AM
Sounds like the fuel tank vent hose is kinked/blocked. This will cause a vacuum in the fuel tank which will eventually cause gas not to flow and the the ATV to "run out of gas"
700xxRider is offline
post #4 of 24 Old 06-25-2018, 10:40 AM
Well I never got around to checking anything yet but I took it out yesterday just to putt around on the farm at lower speeds. I went to take off and it died and took awhile before I could get it started again then took off on it at lower speeds and it acted like it wanted to die and then it finally did and I never could get it started back. I cranked it until battery started dying and ended up pushing it home. I can hear the fuel pump priming when I turn on the key but won't start. So what do I need to check to get my bike fixed? It's very low hours machine and nothing has ever been changed on it other than oil and I would never thought something would happen like this and it so close to new Thanks
04honda is offline
post #5 of 24 Old 06-25-2018, 04:15 PM
Quoted: 62 Post(s)
Might sound dumb, but make sure the fuel selector is on. I could run mine for quite a while on "OFF", I suspect it wasn't completely off but only had a small amount flowing past.
mumbauer is offline
post #6 of 24 Old 06-25-2018, 10:54 PM
The fuel was turned to on position i even switched to reserve and acts no different
04honda is offline
post #7 of 24 Old 06-26-2018, 11:26 AM
Quoted: 62 Post(s)
I figured, but worth making sure. It sounds like either vent hose, filter, pump, etc.
mumbauer is offline
post #8 of 24 Old 06-27-2018, 04:23 PM
Quoted: 252 Post(s)
Question
Are u2 the same person?
post #9 of 24 Old 06-27-2018, 07:57 PM
Yes we r the same person. Not really sure how this happened. It had been long while since I visited the site and had trouble getting onto it but eventually did. I've always went by 04honda on here and other ATV sites.
04honda is offline
post #10 of 24 Old 07-19-2018, 08:56 PM
Ok. I ordered a new Honda Fuel pump put it on and it never helped anything. I took plug out and made sure it had spark. Even sprayed a little starting fluid in air box didn't try to fire any. What else could b wrong with the bike not letting it start? Thanks
04honda is offline
