new air filter ! - Page 2 - Club700XX - Honda TRX700XX Forum
 2Likes
post #11 of 32 Old 06-26-2018, 06:17 AM Thread Starter
/CUDA's Avatar
Quoted: 25 Post(s)
Originally Posted by cataway View Post
BY the way, them little spaces ..are holes
this we are talking:
/CUDA is offline
post #12 of 32 Old 06-26-2018, 07:01 PM
Quoted: 140 Post(s)
yep ……. holes
perhaps you could do a web search on filter test
cataway is offline
post #13 of 32 Old 06-27-2018, 11:06 AM Thread Starter
/CUDA's Avatar
Quoted: 25 Post(s)
yep . holes
Hello,
I watched filter tests,
considering
that K & n
allows passage,
much more air,
the dirt is only slightly higher, acceptable,
then the speech is always that,
where you drive,
and if you give more importance to air,
or by filtration,
here, in Italy, in this area,
there is no desert,
so no drifting on the sand,
so, perhaps, this type of filter do not do damage.
Next step,
it will be, cooling, of the filter box
/CUDA is offline
post #14 of 32 Old 06-27-2018, 02:15 PM
Quoted: 140 Post(s)
''will be, cooling, of the filter box ''
what ?and why ?
cataway is offline
post #15 of 32 Old 06-27-2018, 03:21 PM
Quoted: 224 Post(s)
what ?and why ?
Cold air intake, maybe a supercharger is in the works?
M_Quick is online now
post #16 of 32 Old 06-28-2018, 02:31 AM Thread Starter
/CUDA's Avatar
Quoted: 25 Post(s)
Hello,
the speech is simple,
lower, it's air temperature, airbox
greater, It will be the power.
No, turbocharger, it's too much for me,
I just want to exploit "Peltier cells"
to lower airboxes,
temperature,
just like people do with freezers,
homemade
/CUDA is offline
post #17 of 32 Old 06-28-2018, 08:44 AM
Quoted: 55 Post(s)
The amount of air going through, I'm not sure if that would actually help or not. If you're going to do this, take temp reading (after airbox) before and after mod while you're riding.
mumbauer is offline
post #18 of 32 Old 06-28-2018, 09:03 AM Thread Starter
/CUDA's Avatar
Quoted: 25 Post(s)
Hello,
air flow,
greater
definitely helps, (in these engines with electronic injection, while in carburetors,
you need new setup of fuel)
but also temperature, helps ( always in electronic injection only )
I'll install the filter tomorrow
arrived today,
and next few months, I will install
the system for cooling,
(must arrive from China)
Yes, I have already thought to do a precise test,
same day,
with a temperature measurer, inside airbox,
cooling off and then on
/CUDA is offline
post #19 of 32 Old 06-28-2018, 05:19 PM
Quoted: 140 Post(s)
how much extra power do you believe you are going to get ?
cataway is offline
post #20 of 32 Old 06-29-2018, 02:35 AM Thread Starter
/CUDA's Avatar
Quoted: 25 Post(s)
I think, main gain,
it is in response motor, in torque,
power, it's a little more,
but surely, there will be an improvement, in the whole rpm range,
in all speeds.
The obstacle will be the original muffler,
too closed.
By increasing air, lowering temperature,
also more fuel is injected,
and so I'll have to find a good muffler,
otherwise I'll remove,
the spark arrestor,
which already opens a little
/CUDA is offline
