Motor blew up, top end rebuild! - Page 2 - Club700XX - Honda TRX700XX Forum
post #11 of 46 Old 08-18-2018, 08:42 PM Thread Starter
Quoted: 4 Post(s)
Originally Posted by rebeljake69 View Post
****UPDATE****
I finally got off the cam chain and got the rest of the motor apart, it seems as if m_quick was correct. The cylinder got a crack in it and blew out causing extensive damage to the piston and cylinder. The valves seems to be in okay condition? but I'm not sure if the gap that I tried my best to show is suppose to be there or not; they definitely look used and I will probably be getting new ones since I already have it apart. As far as the crank goes, I'm not to sure on what a bad one would look like? And I don't want to take the motor all the way out of the frame just to check, unless I have to.. Obviously I want to do everything I can to where when I put it back together, I have a quality reliable quad, rather than a ticking time bomb because I halfway did it. Is there any kind of like test or anything that would tell me if the crank was bad? The motor spins great and the piston still goes in its usual motion. The piston arm? is still in good shape it seems. Idk, i have attached some decent photos of the damage done and some things that maybe I thought may need replaced but might not? As I said before, any and all help is much appreciated.
More pictures
rebeljake69 is offline
post #12 of 46 Old 08-18-2018, 10:13 PM
Footy's Avatar
Quoted: 47 Post(s)
Mine was the design of the piston. If you look at the piston, it has skirts on 2 sides. Once one side cracks, there's nothing left to hold it in place. So it slaps around and cracks the jug/cylinder.
So these are stock pistons that are failing and causing the engine to explode?
2017 Honda TRX500 Rubicon
2013 Husaberg FE350
2008 Honda TRX700XX
1995 Honda TRX 300EX
2001 Honda TRX 90
1986 Honda TRX 70
1985 ATC 250 SX
Footy is offline
post #13 of 46 Old 08-18-2018, 11:07 PM
It's just a issue with any slipper piston, imo. And that's what cracked here causing the jug to crack, not the other way around.
post #14 of 46 Old 08-18-2018, 11:13 PM
To OP most people will tell you to replace the crank and bearings. And to do this you will need to pull motor and split the case. If your wrist pin comes out easy, that's a good sign crank may be okay. If you don't wanna replace the crank, you will have to make every effort to clean all the shrapnel out of the bottom of motor. Most of the time when this happens the motor will lock before damaging the crank. I'm wondering since you had the issue with the cam chain if you have the service manual? Also replace the cam chain while apart. And you need to pull your valve springs to check the rods and valve guides in the head. When mine blew all the valve rods were bent and atleast one valve guide cracked.
Sent from Bristol Motor Speedway using Tapatalk
post #15 of 46 Old 08-18-2018, 11:46 PM Thread Starter
Quoted: 4 Post(s)
To OP most people will tell you to replace the crank and bearings. And to do this you will need to pull motor and split the case. If your wrist pin comes out easy, that's a good sign crank may be okay. If you don't wanna replace the crank, you will have to make every effort to clean all the shrapnel out of the bottom of motor. Most of the time when this happens the motor will lock before damaging the crank. I'm wondering since you had the issue with the cam chain if you have the service manual? Also replace the cam chain while apart. And you need to pull your valve springs to check the rods and valve guides in the head. When mine blew the all rods were bent and atleast one valve guide cracked.
I do have the service manual somewhere in my garage, I'm not sure where but I should have found it and researched it rather than googling everything.. Minor setback but I will be sure to do so in the future. The only reason i wouldn't want to replace the crank is the price tag that is on them. But i guess replacing it now would save money in the future so I guess i will go the extra mile into taking everything apart. I'd rather do that anyway just to triple check all of the shrapnel is out. Part of me wants to do whats needed and slap it back together but the other half wants to take my time to do everything correctly to ensure the life of the quad. I just wasn't sure at first if it was 100% necessary to take everything apart since it was just the top end. I guess i'll spend tomorrow ripping it from the cage! I'm sure more pictures will come.
post #16 of 46 Old 08-19-2018, 08:50 PM
Should be a link for the service manual here, in pdf. If you can't find it let me know.
post #17 of 46 Old 08-19-2018, 10:37 PM Thread Starter
Quoted: 4 Post(s)
Got the motor out. Have gotten all the bolts that I could find to split it and couldn't get it to come apart. Not sure if you have to take the main gears off of the main axle in there but I will try to do that when I have my girlfriend there to help. Everything still seems to be in good shape though other than the obviously destroyed stuff. May go ahead and start ordering a couple parts that I know for sure i will need. Any recommendations for anything? I was thinking of the big bore kit but don't know if it's plug and play or I'd have to get the cylinder or whatever machined to make it work. I already know i'm going to get 2 new sprockets both the front and the back ones to increase overall speed, but still try to keep my power down low. That, and i know i will need new tires and wheels shortly after fixing it due to it sitting for so long.
post #18 of 46 Old 08-20-2018, 05:39 AM
Quoted: 36 Post(s)
From what I know, the big bore kit is plug and play. And if you decide to replace your crank, you can replace it with a stroker crank.
Kubi07 is offline
post #19 of 46 Old 08-20-2018, 11:53 AM
Quoted: 5 Post(s)
Pretty interesting posting
barongan is offline
post #20 of 46 Old 08-20-2018, 06:07 PM
so are your only 2 post
