Coolant drip - Page 2 - Club700XX - Honda TRX700XX Forum
 2Likes
post #11 of 15 Old 08-27-2018, 03:30 PM
Originally Posted by 09RappySE View Post
You could do that, and the seal could fail 20 miles down the trail, I bought a whole pump and repaired the old one as a spare. The seal is very easy to replace. I got to believe you can order the seal from Honda.
I don't see it listed in the parts schematics?
Originally Posted by Footy View Post
I noticed today that the drip has occurred again and my 700 has not even been started in weeks. I thought it was only leaking after the engine was running but I guess it is weeping while just sitting.
Partzilla shows $120.75 ships in 2-3 days, meaning they really don't have it! I'd try the seal kit off eBay 1st. Or used pumps on there for like $32 but then again you have a used pump.
post #12 of 15 Old 08-27-2018, 04:36 PM
09RappySE's Avatar
Quoted: 16 Post(s)
Me either, I would call Honda, I can't believe they replace a whole pump when the seal goes.
734 09 Raptor
Tuned by EHS Racing 78hp 55Tq
09RappySE is offline
post #13 of 15 Old 08-28-2018, 05:36 AM Thread Starter
Footy's Avatar
Quoted: 46 Post(s)
Thanks to both of you (Rappy & Quick) for your reply. I want to clarify my situation. I will be riding in WV for 3 days in 1 month from now. I am just wondering if this need to be addressed before I ride? The service manual does state that a drip is normal from the weep hose. I am now more concerned because I saw a new drop of coolant when the engine had not even been started. So I suppose it will drip even without pressure from the water pump operating? I have never had a water pump failure on a bike or atv so I do not know if these will fail all at once or gradually. What would you do in this situation? I don't mind buying the new pump if necessary.
I do not want to be working on this in WV.
2017 Honda TRX500 Rubicon
2013 Husaberg FE350
2008 Honda TRX700XX
1995 Honda TRX 300EX
2001 Honda TRX 90
1986 Honda TRX 70
1985 ATC 250 SX
Footy is offline
post #14 of 15 Old 08-28-2018, 06:47 AM
If you can, I'd do just as Rappy did. Buy a new pump, replace it. And then order the eBay seal kit, to rebuild your original, and save as a spare. Or atleast buy the new pump and replace before your trip. If nothing else your mind will be at ease.
09RappySE likes this.
post #15 of 15 Old 09-12-2018, 03:05 PM
09RappySE's Avatar
Quoted: 16 Post(s)
You will "probably" be fine.....I am sure it is a Teflon/O ring rotating face and they do tend to dry out if they sit. To be honest, I think I made two weekend trips before I finally replaced mine, it was dripping more often but nothing that can't be monitored. If I was planning on a "away" from camp ride, I would replace it before I went because,....you have no idea how "lucky" I am.
734 09 Raptor
