Coolant drip - Club700XX - Honda TRX700XX Forum
 2Likes
post #1 of 15 Old 08-21-2018, 05:42 AM Thread Starter
Footy's Avatar
Quoted: 46 Post(s)
Coolant drip
On 3 different occasions I have noticed a small drop of antifreeze under my 700. After I investigated this drop seems to be coming from the rubber hose that leads from the water pump. I have never seen this before with any other atv or bike. Is a drop from this hose normal? Or is this a sign of a failing water pump or water pump seal?
2017 Honda TRX500 Rubicon
2013 Husaberg FE350
2008 Honda TRX700XX
1995 Honda TRX 300EX
2001 Honda TRX 90
1986 Honda TRX 70
1985 ATC 250 SX
Footy is offline
post #2 of 15 Old 08-21-2018, 01:00 PM
Quoted: 143 Post(s)
water pumps have a weep hole . are you sure its not coming from there ?
cataway is offline
post #3 of 15 Old 08-21-2018, 09:41 PM Thread Starter
Footy's Avatar
Quoted: 46 Post(s)
Is there a hose on the 700xx weep hole?
2013 Husaberg FE350
2008 Honda TRX700XX
2001 Honda TRX 90
1986 Honda TRX 70
1985 ATC 250 SX
Footy is offline
post #4 of 15 Old 08-22-2018, 04:33 PM
Yes there is, they call it a bleed hose! Do you have a copy of the service manual? And do you have skid plates on your trx700? If so it's the rubber hose that sticks through the skid plate. Also I have never notice any leakage from either of my quads, but the manual says a small amount is normal? And there is also a drain bolt and washer on the water pump, that could be leaking? If you have the manual look at chapter 7. 7-20 shows the bleed hose. If you don't have the manual let me know.
post #5 of 15 Old 08-22-2018, 09:44 PM Thread Starter
Footy's Avatar
Quoted: 46 Post(s)
Thanks Mick. Yes I have the manual but I had doubts that it would be that detailed. I will check that chapter out. Yes I found that hose through the skid plate and that is where I found the drip. I now have ricochet skid and there is no hole for the weep hose to pass through. So that leads me to another question. Do I need to do something different with that hose so that It can do what it needs to do? The hose is just squeezed in against the aluminum skid plate at the moment.
2013 Husaberg FE350
2008 Honda TRX700XX
2001 Honda TRX 90
1986 Honda TRX 70
1985 ATC 250 SX
Footy is offline
post #6 of 15 Old 08-23-2018, 08:13 AM
Quoted: 62 Post(s)
If it's squeezed as in it can't flow, then yes. You can drill a hole in the skid plate to let the hose go through, or cut the hose short and have the coolant sit on the skid plate (or find a way to re-route it).
mumbauer is offline
post #7 of 15 Old 08-23-2018, 01:53 PM
09RappySE's Avatar
Quoted: 16 Post(s)
If you are getting coolant out of your weep hole, you water pump mechanical seal is going and will need to be replaced. If it is just a drop every now and then, I would keep an eye on your coolant overflow so it does not run low and plan to change it in the near future as it will only get worse over time.
cataway likes this.
734 09 Raptor
Tuned by EHS Racing 78hp 55Tq
09RappySE is offline
post #8 of 15 Old 08-25-2018, 06:41 AM Thread Starter
Footy's Avatar
Quoted: 46 Post(s)
The parts to rebuild the water pump are not available from Honda or RMATV. They will sell the entire pump for $130 and up. I did find a water pump seal kit on ebay for $17. Not sure which way I want to go at the moment. I may not do anything except keep an eye on the fluid level and how much drips out.
2013 Husaberg FE350
2008 Honda TRX700XX
2001 Honda TRX 90
1986 Honda TRX 70
1985 ATC 250 SX
Footy is offline
post #9 of 15 Old 08-25-2018, 08:10 PM
09RappySE's Avatar
Quoted: 16 Post(s)
You could do that, and the seal could fail 20 miles down the trail, I bought a whole pump and repaired the old one as a spare. The seal is very easy to replace. I got to believe you can order the seal from Honda.
734 09 Raptor
post #10 of 15 Old 08-26-2018, 09:09 PM Thread Starter
Footy's Avatar
Quoted: 46 Post(s)
I noticed today that the drip has occurred again and my 700 has not even been started in weeks. I thought it was only leaking after the engine was running but I guess it is weeping while just sitting.
2013 Husaberg FE350
2008 Honda TRX700XX
2001 Honda TRX 90
1986 Honda TRX 70
1985 ATC 250 SX
Footy is offline
