Just bought stage one performance package from sparks and need help - Club700XX - Honda TRX700XX Forum
post #1 of 8 Old 12-05-2018, 08:31 PM Thread Starter
The guy from sparks told me that the power commander was just plug and play. Is this true? Or do I need to get a better map to make it run better? Also if I have the air box lid for EHS and running the sparks air filters that came with the packages will I have to get a different map?
08700xx97 is offline
post #2 of 8 Old 12-05-2018, 09:49 PM
What power commander did you get? Either way, assuming you have a lap top d/load the PC s/ware. Then install the PC and hook it up to a laptop and pull the map. Save map somewhere, and while hooked up view the map to see if it is in fact a custom map. Most of the times the fuel controllers just come tuned for a stock bike, not one with a full exhaust and intake modified.
post #3 of 8 Old 12-05-2018, 11:21 PM Thread Starter
I got the one that comes with the stage one performance package from sparks. The guy at sparks told me that It would come with the latest tune but since I have a EHS lid will I have to get a custom map? If so can you point me in the direction of someone that could do that for me?
post #4 of 8 Old 12-06-2018, 05:49 AM
A custom tune, means a dyno shop.
post #5 of 8 Old 12-06-2018, 06:07 AM
Footy's Avatar
Quoted: 46 Post(s)
I went through this same crap with my 700xx. I just took some time and installed one tune at a time and then rode the machine in an area with both high speed runs and some slow tight trail. I choose the map that seemed the best to me for good acceleration and not stalling the engine at lower speeds. EHS would probably be the best for tuning but you must buy the tuner that EHS sells in order for them to tune your 700. That will cost you $400 + for the EHS tuner and for EHS to tune your atv plus driving to Rockingham NC.
2017 Honda TRX500 Rubicon
2013 Husaberg FE350
2008 Honda TRX700XX
1995 Honda TRX 300EX
2001 Honda TRX 90
1986 Honda TRX 70
1985 ATC 250 SX
Footy is offline
post #6 of 8 Old 12-06-2018, 05:51 PM
Okay I just went to sparks web site. They do have a custom map, that is made for the lid to be removed. The map is available to d/load, so I wonder if you have to d/load and install it? What gets me after looking at there map, it takes fuel away from the idle from 1000 to 1750 rpms. I'll try and post screen shot later.
post #7 of 8 Old 12-06-2018, 07:06 PM
sparks & Hmf Map
Here is the sparks map, and the HMF one that I'm using. Also you should know that power commander sales a auto tune.
post #8 of 8 Old 04-02-2019, 02:18 PM
09RappySE's Avatar
Quoted: 16 Post(s)
Eric (EHS) can work with your power commander, I forget what his dyno time runs, just give him a call and set it up as it can take awhile.
734 09 Raptor
Tuned by EHS Racing 78hp 55Tq
09RappySE is offline
