Slow Crank but will eventually start...I've tried almost everything - Page 2 - Club700XX - Honda TRX700XX Forum
post #11 of 12 Old 12-13-2018, 04:06 PM Thread Starter
Does it hang when it tries to start, or just crank and not start?
So took it apart again, and check the spacing on the valves. With close attention to the exhaust side.
I think i made a rookie mistake when adjusting them before.
When adjusting you put your spacer in, turn the adjustment with a flat head, get it tight, and tighten the locking nut. however as i was readjusting i realized the force of the flat head sitting on the adjustment screw was throwing off the adjustment tightness. if that make sense, so instead i used my fingers to tighten the screw to the .008, then used the flat head to hold the screw in place while i tighted the lock nut, and sure enouugh she starts right up now. first push of the button.
To anybody with this same issue i hope how im explaining what i did wrong is making sense.
kyleking777 is offline
post #12 of 12 Old 12-13-2018, 06:22 PM
Quoted: 245 Post(s)
Glad you figured it out!
Tags
crank, slow, starter
