Slow Crank but will eventually start...I've tried almost everything - Club700XX - Honda TRX700XX Forum
post #1 of 12 Old 12-11-2018, 03:35 PM Thread Starter
Alright guys, im about at my wits end with this.
When i first got my 2008 700xx (used from original owner), it would fire up instantly. it was also completely stock.
Now that ive had it for about 6 months, ive added a HMF full exhaust, Uni filter running with no lid, and a LEXX EFI programmer.
I've spent alot of time tuning and getting the settings right, which are just ever so slightly from what LEXX recommended for roughly what mods i have. and let me tell you it runs like crazy. There are very few quads that can even come close when me and my buddies race on the beaches. Banshees, 450rs, Raptor 660s and 700s, and quadzillas all fall short.
However, recently it is growing harder and harder to get started. It's not cold weather, bc its really not that cold and it is stored in my heated garage. I assumed it was the battery going bad, so i replaced it an nice AGM battery from my local ATV shop, and the issue was the exact same.
It stuggles to turn that huge motor over, and struggles and struggles, and eventually runs the battery down to the point where it just dies. However i have learned that if i turn the key on, wait for the injectors to rime or whatever the noise is to quit, try to start it, fails, turn key off and back on again, let the noise stop, and hit start, it usually fires right up.
Like i said, once started this thing runs perfect. But starting it just isnt easy anymore. I put in a brand new plug while i had the tank off to adjust the valves, i assumed that was the issue due to my research on here, however it made no changes. they were also not out of spec, but loosened and tightened to spec again just to be safe.
My last resort is put a new starter in it, thinking maybe its what is dragging, but ive tried holding the wires to the starter to see if they feel hot and they do not, ive checked the voltage under load, and the battery is showing 13.12V
I'm hoping the EHS guy will jump in and help bc he seems to know it all.
Any help please?!
kyleking777 is offline
post #2 of 12 Old 12-11-2018, 09:11 PM
Quoted: 143 Post(s)
check the valve lash front right side valve
cataway is offline
post #3 of 12 Old 12-12-2018, 04:35 AM
/CUDA's Avatar
Quoted: 27 Post(s)
Any help please?!
hello, try new spark plug.
/CUDA is offline
post #4 of 12 Old 12-12-2018, 08:10 AM Thread Starter
as stated above i put a brand new plug in when i adjusted my valves!!
post #5 of 12 Old 12-12-2018, 08:11 AM Thread Starter
Could you give me more info on this? i adjusted my valves to spec, but im not sure what you mean by this?
post #6 of 12 Old 12-12-2018, 09:59 PM
Footy's Avatar
Quoted: 46 Post(s)
Sounds like a loose connection with a wire to me. Maybe a loose ground wire. How fast would the starter turn if you jumpered straight to the starter? I would also check the wire going from the regulator/rectifier to the starter selonoid to make sure it is tight.
2017 Honda TRX500 Rubicon
2013 Husaberg FE350
2008 Honda TRX700XX
1995 Honda TRX 300EX
2001 Honda TRX 90
1986 Honda TRX 70
1985 ATC 250 SX
Footy is offline
post #7 of 12 Old 12-13-2018, 04:03 AM
/CUDA's Avatar
Quoted: 27 Post(s)
Probably,
your chip,
change the signal too much,
and in engine ignition,
fuel /air ratio,
it's too much, fat,
just for test,
see if without lid of air filter,
engine starts well,
or, try decrease chip setting
/CUDA is offline
post #8 of 12 Old 12-13-2018, 01:18 PM
Sounds like you figured it out! The noise is the fuel pump priming. I always do this when cold starting, but instead of the key switch, I just hit the kill switch off to back on. If quad sits for a bit, it isn't uncommon for them not to turn right over. I generally always have to dbl prime mine when cold, and they haven't run for a week or so.
post #9 of 12 Old 12-13-2018, 01:43 PM Thread Starter
Except this is also the case when i have been riding for a couple hours, if i shut off the quad, it will be a struggle to get it started up again.
post #10 of 12 Old 12-13-2018, 01:47 PM
Does it hang when it tries to start, or just crank and not start?
Tags
crank, slow, starter
