Is a stage 3 HotCam worth it without other engine work? If so, How to? - Club700XX - Honda TRX700XX Forum
post #1 of 10 Old 01-10-2019, 02:38 PM Thread Starter
My exact Mods are as followed:
Full HMF Performance Full Exhaust
UNI Foam filter
No lid
13T front sprocket
5/8 Sway bar
Steering Damper
Without any other mods to the engine, is a stage 3 cam worth doing? will i see a decent bump in Power? Speed? how much?
I ride a lot in sand, but also do a lot of tight technical trails. I've read a stage 2 is a waste of time and you might as well do a stage 3? is this true?
I do not want to lose any reliability, Or low end power.
From what ive read its a fairly simple job, however i have zero experience in it.
I just adjusted my valves, and it is now running better than ever, how much further do you have to tear down to swap out the cam? How do i get the timing chain on and off and make sure that i get it back on corerctly. Im completely new at this so any help would be great.
Thanks so much.
kyleking777 is offline
post #2 of 10 Old 01-10-2019, 08:34 PM
Quoted: 141 Post(s)
UNI Foam filter
No lid
13T front sprocket
5/8 Sway bar
Steering Damper
Thanks so much.
hummm, ahhhh...... well .....i'm thinking you should have some one do it for you
cataway is offline
post #3 of 10 Old 01-11-2019, 05:14 AM
/CUDA's Avatar
Quoted: 27 Post(s)
UNI Foam filter
No lid
13T front sprocket
5/8 Sway bar
Steering Damper
Thanks so much.
without programmer,
with current mods,
your trx should be very lean
/CUDA is offline
post #4 of 10 Old 01-11-2019, 03:45 PM Thread Starter
UNI Foam filter
No lid
13T front sprocket
5/8 Sway bar
Steering Damper
Thanks so much.
without programmer,
with current mods,
Sorry!!! I also have a LEXX EFI tuner.
post #5 of 10 Old 01-11-2019, 05:34 PM
Quoted: 251 Post(s)
It will be noticeable, and well worth the $150 investment, unless your talking about a web cam. then of coarse you will need the h/duty springs and h/welded rockers. Which are a good investment as well.
Edit, also if you do add the cam, you should probably replace the chain while at it.
post #6 of 10 Old 01-11-2019, 07:48 PM
Quoted: 141 Post(s)
yep new chain , great idea
did all that plus +1 on the intake valves and cleaned up the porting .then went one step farther and did one more mod to get more oil to the camshaft .
cataway is offline
post #7 of 10 Old 01-13-2019, 03:43 PM
09RappySE's Avatar
Quoted: 16 Post(s)
Then up the compression to get back the little bit of bottom end you are going to lose with HC3.
734 09 Raptor
Tuned by EHS Racing 78hp 55Tq
09RappySE is offline
post #8 of 10 Old 01-14-2019, 08:57 AM Thread Starter
Do you really lose that much low end? from what ive read it is about the same as stock on low end, but mid and high is a huge improvment. Not that im lacking any of that from my current mods, but
post #9 of 10 Old 01-16-2019, 06:55 AM
Footy's Avatar
Quoted: 43 Post(s)
personally I would not add the cam until you need to go into the engine for a bigger reason. Like these other guys have said then do these other mods to keep the engine strong internally as well as on the dyno. If you just want to spend some money on your 700 I would spend money on suspension, tires and beadlock wheels. I come from the school of thought that if you spend more money on the fuel going through your engine the atv will start going a lot faster because the operator will be more comfortable and confident. Point being if you are buying lots of fuel for the atv then you must be riding it a lot. Seat time is what I need more than anything.
2017 Honda TRX500 Rubicon
2013 Husaberg FE350
2008 Honda TRX700XX
1995 Honda TRX 300EX
2001 Honda TRX 90
1986 Honda TRX 70
1985 ATC 250 SX
Footy is offline
post #10 of 10 Old 01-16-2019, 08:54 PM
09RappySE's Avatar
Quoted: 16 Post(s)
Can't have your cake and eat it too without supporting mods.....It may not be as noticeable on the XX, but you will loose some. On the raptor, its not huge, but you can notice it, and the stock piston sucks anyway.lol
All motors love compression.
734 09 Raptor
