Won’t start - Club700XX - Honda TRX700XX Forum
post #1 of 4 Old 01-21-2019, 11:15 AM Thread Starter
Won’t start
Started my 700xx up the other day Started up no problems let it set and warm up after about 40min of it setting there running It started missing and shut down I tried starting it back up it will run for about a second shut off
WV hillbilly84 is offline
post #2 of 4 Old 01-21-2019, 03:37 PM
40 min warm up time? Sounds like out of fuel. Or just fuel valve is off.
post #3 of 4 Old 01-22-2019, 01:54 AM
Quoted: 143 Post(s)
dodo happens. you do make it sound like you dont have enough gas in the tank.
on a different quad of mine the gas cap vent was plugged ,it would run for a bit and then stall out .first thing i'd do is take the gas cap off to see if I was out of gas . that would of course relive the vacuum in the tank and would then run a bit longer, then stall out yet again till I turned opened the gas cap .
cataway is offline
post #4 of 4 Old 01-23-2019, 02:17 AM
/CUDA's Avatar
Quoted: 27 Post(s)
If the engine turns off when you put the gear, you need to adjust the clutch
/CUDA is offline
