-   Motor, Transmission, Electrical, Intake & Exhaust (https://www.club700xx.com/vb/8-motor-transmission-electrical-intake-exhaust/)
-   -   I think I have a problem (https://www.club700xx.com/vb/8-motor-transmission-electrical-intake-exhaust/34038-i-think-i-have-problem.html)
JPP 04-09-2019 06:14 AM
Hello guys. That's it. I wanted to drop the right axis to grease as advised by the forum but it is stuck. I emptied a can of WD-40 and I levered for a moment but nothing helps, he still does not want to go out. Questions: Is it possible to remove the left axle before the right for easier access to the circlip? As the quad works correctly for the moment, is not it better that I wait for it to break for good and so, change the parts that will be out? Or does anyone have a cooler way to take it out without breaking anything? What do you think ?
M_Quick 04-09-2019 08:58 PM
Some user have used the knock out hole on the left side, to drive the right axle out.
cataway 04-09-2019 09:04 PM
yes but then where do you get a new plug ?
shaft will come out but you do have to put some Sirius leverage on it
JPP 04-09-2019 11:44 PM
But for that, you still have to take out the left axis first, is that possible?
M_Quick 04-11-2019 03:21 PM
I'd read through the whole thread, but start at post 199 for left axle removal and knock out info...
https://www.club700xx.com/vb/8-motor...emoval-20.html
JPP 04-14-2019 07:36 AM
Yes I have read this thread several times but I can not imagine how we can access the axis on the right side. It's not detailed enough for me, I think.
M_Quick 04-14-2019 08:08 AM
2 questions then. 1st what exactly are you having issues with? 2 do you have the service manual?
JPP 04-15-2019 12:12 AM
1: my problem is that i want to remove the right shaft to put fat but it is stuck. So I ask here, if there is a way to get out without anything damaged because the quad works like that. Until when I do not know?
And I know (compared to what I read in this forum) that if I force like a brute to release it, the pieces will be damaged and I have several pieces to replace.
2: yes I have the service manual
M_Quick 04-15-2019 05:43 AM
I'd spray the hell out of it with liquid wrench. Get a large tie-rod tool, that's wider than the axle. Line it up with the bolts on the rotor. Smack with hammer, spin axle smack, repeat.
JPP 04-15-2019 06:26 AM
But by hitting it like a sick person, I don’t risk breaking something? (for example, the circlips that remains blocked)
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging v3.1.0 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
