Hello guys. That's it. I wanted to drop the right axis to grease as advised by the forum but it is stuck. I emptied a can of WD-40 and I levered for a moment but nothing helps, he still does not want to go out. Questions: Is it possible to remove the left axle before the right for easier access to the circlip? As the quad works correctly for the moment, is not it better that I wait for it to break for good and so, change the parts that will be out? Or does anyone have a cooler way to take it out without breaking anything? What do you think ?
Yes I have read this thread several times but I can not imagine how we can access the axis on the right side. It's not detailed enough for me, I think.
1: my problem is that i want to remove the right shaft to put fat but it is stuck. So I ask here, if there is a way to get out without anything damaged because the quad works like that. Until when I do not know?
And I know (compared to what I read in this forum) that if I force like a brute to release it, the pieces will be damaged and I have several pieces to replace.
2: yes I have the service manual
I'd spray the hell out of it with liquid wrench. Get a large tie-rod tool, that's wider than the axle. Line it up with the bolts on the rotor. Smack with hammer, spin axle smack, repeat.
OK Lol. But it’s just that I have a quad release scheduled with the buddies soon and I wouldn’t want to be the only one left in the garage because I wanted to put grease on an axis. I’ll try next time.
Yes, I’ll plan everything before we start. Thank you. Another question: is there a kit (pivot works for example), to replace the small bearings of the rear wheel hub? (between wheel hub and arm). Or should you buy the original part directly and separately?
Related Threads
134.3K posts
31.7K members
Since 2007
