oils differences - Club700XX - Honda TRX700XX Forum
post #1 of 6 Old 04-15-2019, 05:51 AM Thread Starter
/CUDA's Avatar
Quoted: 27 Post(s)
oils differences
Hi guys,
I'm using 10w40 oil,
I do not quote brand,
it is not a matter of advertising.
I am tempted to apply a 10w50,
to have a gear change, fluid, even when hot,
and also to better protect engine,
but I'm going in the right direction,
or?
Who tried w50 oil, and what are the differences with w40?
Engine, warmer, or less hot,
or the same?
Change of gear ..
Clutch, it works fine anyway, or worse
Thank you all
/CUDA is offline
post #2 of 6 Old 04-15-2019, 06:41 AM
JPP
JPP's Avatar
Quoted: 8 Post(s)
I use IPONE KATANA 10W50 for a long time and no problem with it. Drain + filter every 1000 km or so.
JPP is offline
post #3 of 6 Old 04-15-2019, 03:58 PM
09RappySE's Avatar
Quoted: 16 Post(s)
50 weight is awfully thick for your oil pump to reach your valve train.......I would not use it, but that's me.
734 09 Raptor
Tuned by EHS Racing 78hp 55Tq
09RappySE is offline
post #4 of 6 Old 04-16-2019, 04:11 AM Thread Starter
/CUDA's Avatar
Quoted: 27 Post(s)
thanks guys, maybe I'll go to another 10w40
which, however, is a little more dense than the classic 10w40
(on the data sheet)
here in Italy, it is very famous and used, it is an American product,
called bardhal
/CUDA is offline
post #5 of 6 Old 04-16-2019, 06:12 AM
JPP
JPP's Avatar
Quoted: 8 Post(s)
You put me in doubt so I went to check out the garage and it’s KATANA 10W40. So much for me😁
JPP is offline
post #6 of 6 Old 04-16-2019, 08:41 AM Thread Starter
/CUDA's Avatar
Quoted: 27 Post(s)
You put me in doubt so I went to check out the garage and itís KATANA 10W40. So much for me😁
merci!
/CUDA is offline
