crankcase breather - Club700XX - Honda TRX700XX Forum
 2Likes
post #1 of 11 Old 06-05-2019, 04:53 AM Thread Starter
/CUDA's Avatar
Quoted: 27 Post(s)
crankcase breather
Hi everyone,
after an abundant year I have this quad,
I believe mine has a problem,
or it is a factory defect.
Practically,
I put oil at maximum,
but he spits out,
from the crankcase vent,
and the level drops to the minimum,
so i was thinking to bring this tube,
it too, inside the filter,
what do you think ?
/CUDA is offline
post #2 of 11 Old 06-05-2019, 02:30 PM
nacho's Avatar
Quoted: 11 Post(s)
The 700xx has a rather strange way of checking the oil. You need to let the engine run for about 5 minutes, then turn it off. Immediately check the oil upon shutting the engine off. I hope his solves you problem.
TRX700XX
KFX700
TRX250EX
85 ATC250R
nacho is offline
post #3 of 11 Old 06-05-2019, 06:46 PM
Quoted: 251 Post(s)
Are you talking about the tube on the air box that rest against the air filter? If so you have some serious issues!
And I agree with Nacho, hard to get accurate oil level reading. So you may be over filling. Best to just drain and start fresh. If after a oil change its spitting oil out the vent, you have a issue for sure.
post #4 of 11 Old 06-05-2019, 07:42 PM
Quoted: 141 Post(s)
a different quad of mine did something similar. it would pump oil out . it has broken rings
cataway is offline
post #5 of 11 Old 06-06-2019, 04:32 AM Thread Starter
/CUDA's Avatar
Quoted: 27 Post(s)
Thank you all !
I mean the vent below,
see photo,
I checked with my finger,
and it was all wet with oil, inside.
My research is due because oil always seems to come down, the level,
but I never respected,
oil check as the manual, says, this is true.
Anyway, guys, if I'm not wrong,
this I'm pointing, it crankcase breather,
while the one in the air filter,
comes from the oil tank.
/CUDA is offline
post #6 of 11 Old 06-06-2019, 04:38 PM
Deephaven's Avatar
Quoted: 21 Post(s)
If that is your machine you need to RIDE it! The oil check procedure is goofy. I thought you were supposed to leave it running...but haven't looked since the day I bought mine.
Deephaven is offline
post #7 of 11 Old 06-07-2019, 04:36 AM Thread Starter
/CUDA's Avatar
Quoted: 27 Post(s)
Hello,
no, mine is the gray one in my avatar's photo,
however, I removed a little oil,
with a syringe,
and I decided, put a thickness,
under rear wheels,
as if he had back 22 tires
and 21, front
as original
and follow oil procedure, just like manual says,
and see a little
What happen !
/CUDA is offline
post #8 of 11 Old 06-07-2019, 01:08 PM Thread Starter
/CUDA's Avatar
Quoted: 27 Post(s)
REPORT:
Honda is always accurate,
we are inaccurate (for we I mean me!)
I put TRX in a perfect plan,
and considering as if it had 22 "tire rear
and 21 "tire front,
result, wonderful.
After 5 minutes without accelerating,
I turn off the engine,
and check immediately, without screwing the dipstick,
oil was at the highest level !!!
Just the time to do second measurement,
after 15-20 seconds
and level fell to mid-level !!!
So it must be a quick operation,
and check only once!
This process, plan,
and as if there were standard tires,
I think it is also ideal in,
Oil change,
otherwise it might not come out all,
as in my case...
having front 23 "tire,
and 21 "rear ..
Moreover, I applied a small extension,
to the vent pipe, in the filter box,
to prevent losses,
or limit them,
during wheelies !!!
/CUDA is offline
post #9 of 11 Old 06-07-2019, 05:24 PM
Quoted: 251 Post(s)
headscratch
Originally Posted by /CUDA View Post
Thank you all !
see photo,
This photo is pointing at the water pump drain hose. So I really hope your not dropping oil out of it.
/CUDA likes this.
post #10 of 11 Old 06-08-2019, 03:56 AM Thread Starter
/CUDA's Avatar
Quoted: 27 Post(s)
M_Quick you are a genius!
About 15 days ago,
I did change oil and filter,
(the mechanic did)
the trx was on a slight false floor,
a little sloping,
and not all the oil had come out (I understood that, later)
I had 3 liters of new oil, I said mechanical, put 2 liters
but towards the end, the oil tank,
it filled up completely,
and a lot of oil out of it,
dirtying everything,
including that tube !!!
So all right, my water tank, radiator,
it's nice clean,
always green liquid, like 1 year ago, I'm calm.
Only problem,
currently, the oil is like a blend,
with the previous one,
but they are both 10w40
there should not be any problem,
to change again, urgently,
also because it is an oil of 20 euros almost, per liter.
Thanks again
this forum is great !!!
/CUDA is offline
