So I've been slowly rebuilding my engine and made it to the clutch reassembly. It seems as if something is wrong with it but i'm not sure what it is. It seems almost like the clutch is engaged but the motor is split so I don't see how that could be the case. I try to put the plate back on with the spring loaded screws and the middle piece sticks out and will not go any further, even with some of the bolts screwed in to see what would happen. I turn that piece around and it seems to work fine but it looks a lot different than when I took it apart. I have attached comparison pictures from when I was taking it apart, and when the little middle piece is turned both ways. Any help is much appreciated!
