Need transmission help - Club700XX - Honda TRX700XX Forum
post #1 of 9 Old 01-07-2020, 12:38 PM Thread Starter
I bought a 700xx off a guy, and the top end was off of it. Put it in, and transmission will only shift down once and up once. I pulled the clutch side case off, every thing looks good, reverse light comes on, thought maybe it was something with the reverse, so I pulled the reverse rod off, and it still does the same thing. Any help would be appreciated.
Quad411 is offline
post #2 of 9 Old 01-07-2020, 01:30 PM
Quoted: 144 Post(s)
I would speculate the shifting shaft is the problem. it can be removed with out removing motor yet not far from it. yep its a pain in the ass doing it but still better than removing the motor. leave the front side bolt in place, loosen it, its going to be a pivot point so that you can lift the rear of the motor up to get the shaft out
cataway is offline
post #3 of 9 Old 01-07-2020, 01:36 PM Thread Starter
I've got that side of the motor apart, what part of the shift shaft do you think is the problem, it doesnt appear to be bent or anything?
Quad411 is offline
post #4 of 9 Old 01-07-2020, 01:41 PM
Quoted: 144 Post(s)
this is a bad one
cataway is offline
post #5 of 9 Old 01-07-2020, 01:44 PM Thread Starter
I'll pull it out and take a look at it again, closer
Quad411 is offline
post #6 of 9 Old 01-07-2020, 08:01 PM Thread Starter
Here are a couple pics I snapped, everything looks good as far as I can see.
Quad411 is offline
post #7 of 9 Old 01-07-2020, 09:27 PM
Quoted: 144 Post(s)
in the pic on the right ,there is a hole . did you remove what was there ? hope you still have it. I now hate to think whats wrong. have you ever split trans, cases before ?
cataway is offline
post #8 of 9 Old 01-07-2020, 09:42 PM Thread Starter
which hole, The shift shaft? which I pulled to take pictures of, or the reverse rod, which I took out to see if it was hanging up on something? I've never split 700xx cases before, but I have done plenty 250R's, 450R's and YFZ450's
Quad411 is offline
post #9 of 9 Old 01-07-2020, 09:44 PM
Quoted: 144 Post(s)
where the rear wheels turning when you where tiring to shift ?
cataway is offline
