All Dash Lights Not Working - Club700XX - Honda TRX700XX Forum
post #1 of 8 Old 01-13-2020, 10:29 PM Thread Starter
SirGregoryDesigns's Avatar
Any help that can be provided when all the lights started not working at once is appreciated. I cannot imagine all sensors going out at once but I guess anything is possible. I checked the main connection to the lights and they appear fine. Where should I start trouble shooting...maybe replace the neutral or reverse sensor? Thanks for any help!!
SirGregoryDesigns is offline
post #2 of 8 Old 01-14-2020, 08:27 PM
Quoted: 260 Post(s)
Does the quad still run, and what about head & tail light? If no lights I'd check your 10 amp fuse.
post #3 of 8 Old 01-14-2020, 08:46 PM Thread Starter
Thanks for the follow up....the quad starts and runs fine. I checked and the Headlight works fine but did not check the tail or brake light. I will check and let you know
post #4 of 8 Old 01-14-2020, 09:09 PM
Quoted: 260 Post(s)
Not 100% but pretty sure all lights run off the 10amp fuse. Still a good idea to check your fuse, but possibly a loose connection. Like you said, doubt all sensors would go at once.
post #5 of 8 Old 01-14-2020, 09:53 PM Thread Starter
Thank you ....checked the tail lights and they are working fine. Any other ideas of things or places to check would be awesome
post #6 of 8 Old 01-15-2020, 10:39 AM
Quoted: 144 Post(s)
there is a connector in the harness ,thinking its green . could of lost it grounding
cataway is offline
post #7 of 8 Old 01-15-2020, 08:31 PM Thread Starter
Thanks. All the lights stopped working after I installed a IMS tank, a new steering stem and put everything back together. I guess next step is to take apart, check the ground and see what is going on under the tank. I’ll provide an update on the findings and may have additional questions. Thanks again!
post #8 of 8 Old 07-30-2020, 03:12 AM
Quoted: 4 Post(s)
Any update? Is it a ground issue?
dreicon is offline
