Any help that can be provided when all the lights started not working at once is appreciated. I cannot imagine all sensors going out at once but I guess anything is possible. I checked the main connection to the lights and they appear fine. Where should I start trouble shooting...maybe replace the neutral or reverse sensor? Thanks for any help!!
Thanks for the follow up....the quad starts and runs fine. I checked and the Headlight works fine but did not check the tail or brake light. I will check and let you know
Not 100% but pretty sure all lights run off the 10amp fuse. Still a good idea to check your fuse, but possibly a loose connection. Like you said, doubt all sensors would go at once.
Thanks. All the lights stopped working after I installed a IMS tank, a new steering stem and put everything back together. I guess next step is to take apart, check the ground and see what is going on under the tank. I’ll provide an update on the findings and may have additional questions. Thanks again!
Related Threads
134.3K posts
31.7K members
Since 2007
